help with my 4.0 in xj Started all over - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 19th, 2013, 02:05 PM   #1
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Send a message via Yahoo to ttrailtj
Default help with my 4.0 in xj Started all over
Ran great when i parked it last night, today just cranks and cranks, not even a sputter, fuel rail is full of gas, any ideas? Its a 97
ttrailtj is offline   Reply With Quote
Old September 19th, 2013, 02:26 PM   #2
xj4life
xj4life's Avatar
crank position sensor
Old September 19th, 2013, 04:50 PM   #3
yyj87
yyj87's Avatar
What he ^ said +
Do you get a check engine light when you turn the key to the on position?
Is the fuel rail pressurized or just full?
yyj87 is offline   Reply With Quote
Old September 19th, 2013, 04:52 PM   #4
Dylan
Dylan's Avatar
check for spark. x2 on crank sensor. If you get spark, than chances are crank sensor is ok and its something else.
Old September 19th, 2013, 06:51 PM   #5
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
The check engine light came on a few days ago after an oil change , I am not relating the two, or I hope not, I will have my tools tomorrow, its at my GF's house Thanks so far for everyones help
Old September 21st, 2013, 02:52 PM   #6
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
New cps, new cap and rotor , still no fire ???
Old September 21st, 2013, 02:57 PM   #7
WACKO1
2000 xj
WACKO1's Avatar
Cam sensor
WACKO1 is offline   Reply With Quote
Old September 21st, 2013, 02:58 PM   #8
WACKO1
2000 xj
WACKO1's Avatar
We're is it at ?
Old September 21st, 2013, 03:13 PM   #9
skife
skife's Avatar
first off, what year is it?
second off, what codes is it throwing?
if it gets spark, check fuel pressure.
i believe there is only a cam sensor on 00+ XJs
Old September 21st, 2013, 03:37 PM   #10
yyj87
yyj87's Avatar
Turn the key to the on position without starting, you should get a check engine light for about 3 seconds and the fuel pump should run for 2 seconds or so.
If you have no cel/fuel pump/spark your pcm isn't getting power.
If you get a cel and fuel pump runs but no spark its probably ckps/cps issue.
The above applies to obd1, I think the obd2 is setup the same way. I'm sure someone here can confirm.
Old September 21st, 2013, 03:39 PM   #11
yyj87
yyj87's Avatar
My 91 yj has one under the dizzy, every 4.0lI have touched has been the same way.
Old September 21st, 2013, 03:39 PM   #12
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Its a 97 i dont have away to check codes guess maybe the coil, hate to keep buying crap if it dont need it put some starter fluid to it also ,nothing , checked all grounds also.
Old September 21st, 2013, 09:33 PM   #13
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Maybe the pickup coil?
Old September 21st, 2013, 10:12 PM   #14
WACKO1
2000 xj
WACKO1's Avatar
Turn the key on and off 3 times. The engine light will flash the code,count the flashes and let me know I will look them up for you, also check to see if you have power at the coil connector while some one cranks the engine.
Old September 21st, 2013, 10:14 PM   #15
Dylan
Dylan's Avatar
did you even check for spark or just start swapping parts? If you haven't yet checked for spark, do that first. just pull a plug wire and get an extra plug or a spark tool. if no spark, check the coil plug. One wire will be 12v+ with key on and the second should be - pulse while cranking. If you get no spark and the end of the spark plug wire but - pulse at the coil plug, chances are your coil is bad. Before swapping coils, check the wire from the coil to the distributer. If the wire is good, than chances are your coil is bad. If you do not get 12v+ at the coil plug, than you have a short somewhere on that wire you need to find.
If you do not get - pulse at the coil plug when cranking, you need a scan tool that can give you a live feed of the crank/cam signal to make sure they are working fine. Basically there is a few things you can do to actually diagnose the problem instead of just throwing parts at it.
Old September 22nd, 2013, 01:22 PM   #16
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
I tried that, the light just stays on , will check power to coil later, ,this is driving me nuts, and its probably something simple.
Old September 22nd, 2013, 01:33 PM   #17
shreddedbark
shreddedbark's Avatar
Press and hold the odometer reset while turning the key to the on position. This will give you any code that it's throwing.
shreddedbark is offline   Reply With Quote
Old September 22nd, 2013, 02:44 PM   #18
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Did this, and it lit up the shift light and cruse light, this xj dont have either, then the odometer went 9999999,8888888,7777777,down to zeros the just showed the mileage, the all lights went off and check engine lit back up ??
Old September 22nd, 2013, 02:50 PM   #19
Dutchman390
better built than bought
Dutchman390's Avatar
have any way to check ohms on coil? if you can compare that reading to a spec sheet on the internet. possibly open coil?
Dutchman390 is offline   Reply With Quote
Old September 22nd, 2013, 02:57 PM   #20
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Kind of limited with testing tools , guess a flat bed to a repair shop ?
Page generated in 0.62239 seconds with 83 queries
