3 Link DIY Kit w/ 7/8" Heims - Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 19th, 2013, 11:55 AM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default 3 Link DIY Kit w/ 7/8" Heims - Barnes 4wd
Barnes 4wd 3 Link DIY Kit w/ 7/8" Heims
All kits ship with brackets pre-drilled to the correct bolt hole size and no extra cost!
This is the kit that has all the parts that we are always using in the shop for customers three link suspensions. This has all the parts that are made to stand up to the abuse that is seen by rock crawlers, trail rigs, and the weekend warriors. It includes:
1 x Axle Link Mount Pair 10 Deg
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount 0 Deg
1 x Link Tower
1 x Outside Frame Panhard / Trackbar Mounting Bracket
1 x Offset Axle Panhard Bracket
1 x Chromoly 3/4 - 16 X 3/4" Heim RH
1 x Chromoly 3/4 - 16 X 3/4" Heim LH
2 x High Misalignment Spacer - 3/4" to 5/8" Stainless Steel (pair)
1 x 3/4" - 16 Jam Nut RH
1 x 3/4" - 16 Jam Nut LH
1 x Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube RH
1 x Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube LH
3 x Chromoly 7/8"-14 x 3/4" Heim RH
3 x Chromoly 7/8"-14 x 3/4" Heim LH
6 x High Misalignment Spacer - 3/4" to 5/8" Stainless Steel (pair)
3 x 7/8"-14 Jam Nut RH
3 x 7/8"-14 Jam Nut LH
3 x Tube Insert (7/8"-14) 1 1/2" ID 1 3/4"OD Tube RH
3 x Tube Insert (7/8"-14) 1 1/2" ID 1 3/4" OD Tube LH
This is great for the do it your self fabricators looking do their own 3 link system, and did we mention that the kit is 5% off of our regular great prices for the items individually!
Barnes 4wd is offline   Reply With Quote
Old October 4th, 2013, 10:33 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Just wanted to let you guys know that we updated our pricing and it has gone down to $375.15!
Old February 19th, 2014, 09:12 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
These kits are always in stock and ready to ship, if you would like to change out any of the brackets or order it with a different style of joint let us know by emailing us at sales@barnes4wd.com!
Thread Tools
Page generated in 0.25338 seconds with 32 queries
