3 Gun Rig - High End AR15. Noveske chainsaw lower, White Oak Arms Upper, Primary Arms - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Firearms
Old September 19th, 2013, 10:23 AM   #1
catalyst
catalyst's Avatar
Default 3 Gun Rig - High End AR15. Noveske chainsaw lower, White Oak Arms Upper, Primary Arms
What:
3 Gun Rig - High End AR15. Noveske chainsaw lower, White Oak Arms Upper, Primary Arms 1-4x, Magpul, etc.
Item is New or Used?
USED
Preferred Contact Method
PRIVATE MESSAGE (PM)
Item Location:
Roseville
Price or Trade Value:
1600
Item Description:
Picked up a new rifle, so I'm selling my old 3-Gun Rig. Works Perfectly!
It has exactly 440 rounds through it. All brass cased. Cleaned and oiled after every use.
Noveske Chainsaw Billet Lower
Magpul Rubberized Grip w/ storage
Daniel Defense Lower Parts kit.
JP Yellow Trigger Springs
Has a nice, clean, crisp break.
Yankee Hill Machine (YHM) Extended Takedown Pins
16" White Oak Armament Factory Built upper.
Stainless Steel 16" match-grade barrel.
Mid-length Gas system
Chambered in .223 Wylde
1-7 twist
15" Troy Alpha Free Float Rail
Aluminum Rail Section front lower handguard
Tromix Shark Muzzle Break
Magpul Stock
VTAC / Viking Tactical Single Point Sling with QD Release
Noveske QD Butt plate / sling mount.
Primary Arms Extended 30mm 1 piece Scope Mount
Primary Arms 30mm 1x-4x Optic with illumination. This scope will likely need to be sighted in, as I pulled off my SWFA 1-6x. The Primary Arms 1-4x is solid, I had it on my backup rig and it has ~100 rounds on it.
30 round Pmag.
Rifle Case
This thing is an amazing shooter and shoots sub moa groups. The barrel on this thing is absolutely amazing. If I didn't have another rifle I wanted to use, it wouldn't be going anywhere.
I'm not looking for any trades unless you have a SCAR 16/17 you need to part with.
catalyst is offline   Reply With Quote
Old September 27th, 2013, 04:14 PM   #2
aber61
aber61's Avatar
Sweet piece, GLWS
aber61 is offline   Reply With Quote
Old September 29th, 2013, 09:52 AM   #3
catalyst
catalyst's Avatar
thanks - its a really sweet shooter. WOA makes some really nice uppers.
Page generated in 0.17839 seconds with 32 queries
