1987 Jeep Wrangler YJ ***SOLD**** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 18th, 2013, 04:51 PM   #1
dmcjeep
dmcjeep's Avatar
Default 1987 Jeep Wrangler YJ ***SOLD****
Typical old YJ has rust in the body. Frame is in surprising good condition. Frame is not perfect but still very useable. The Jeep runs good and drives pretty good also. Would make a nice trail/beater Jeep. Has a 4.2L with manual 5 speed transmission. There are of course some issues. Has tilt column and the tilt is very sloppy. I am pretty sure that due top the tilt problem the ignition quit working properly and some one installed an on/off switch with push button starter. There are a couple extra good things also. Has an aftermarket HEI distributor and what I believe to be a weber carb. Jeep has also had the front vacuum actuator switched over to a cable disconnect. The Jeep does NOT have a top or doors.
dmcjeep is offline
Old September 18th, 2013, 07:41 PM   #2
jsmtam90
Old School Jeeper Club
jsmtam90's Avatar
pm sent
jsmtam90 is offline
Old September 18th, 2013, 08:24 PM   #3
mr crawl
Mr Crawl
mr crawl's Avatar
pm sent I have cash and a car hauler you can consider this sold
mr crawl is offline
Page generated in 0.18517 seconds with 32 queries
