E250 Tach Install - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2013, 01:08 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default E250 Tach Install
I've searched around the web and haven't had much luck finding any info on installing a tach into a 2002 Ford E250. From what I can find, I need a certain type of tack for this thing, and there may or may not be a certain wire I need to find to run the tachometer.
Can anyone help me get started in the right direction here?
Old September 17th, 2013, 01:27 PM   #2
Ebs
You could do a dash swap for one with a factory tach, but that year probably has the security key and the stealership will have to program the dash with the key. At least that is what I found researching a dash swap for my similar year F150 that has me shifting by braille.
Old September 17th, 2013, 01:38 PM   #3
shawn
shawn's Avatar
A tach was never an option on most all years of the E-Series. And since this is an 02, I would need an 01 or earlier gauge cluster from an F-series and even then all the wiring is different even though the cluster will physically fit just fine.
I need to find out if I have this "CTO" wire I've been reading about. I just can't find what years had them.
Old September 18th, 2013, 01:38 PM   #4
shawn
shawn's Avatar
Ok. Found the CTO wire, it was sticking out of the wire harness above the brake booster. I picked up a Sunpro Tack from Autozone, and it works great. That was easier then I thought it was going to be.
Page generated in 0.17907 seconds with 35 queries
