Ratchet Straps - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2013, 09:30 AM   #21
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Originally Posted by amc78cj7 View Post
I had these and the hook snapped on one once...
That's scary. Did they warranty it?
Old September 17th, 2013, 09:40 AM   #22
mschaffer66
mschaffer66's Avatar
Originally Posted by brewmenn View Post
Probably Macs. http://www.macscustomtiedowns.com/category/TieDowns
That's what I have. They work good. I like having the axle strap, makes it easier .
I like the axle strap and ratchet instead of the axle strap/ratchet combo.
My axle straps are showing considerably more wear than the ratchet straps themselves. I guess I'd like to just be able to replace an axle strap instead of having to replace the whole contraption.
Old September 17th, 2013, 09:43 AM   #23
bigbchevy
missmrgreenagain
bigbchevy's Avatar
2inch ftw
H.o.r.e
Old September 17th, 2013, 09:44 AM   #24
amc78cj7
amc78cj7's Avatar
No idea. I stopped at a truck stop and checked the straps. Saw one with a snapped hook and scrapped it. Fortunately I have 4 on the Jeep so still had 3 holding it in place. Bought a set from the truck stop with big HD hooks and have been using them ever since.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old September 17th, 2013, 09:54 AM   #25
T_J
Make it or Break it
T_J's Avatar
Joe,
One word of advice I learned after buying my own straps. Find a good material to keep with your set to use as a softener. I use cardboard but they manufacture curved plastic things for the actual purpose. Tuck it in between the strap and any surface that has an edge to it. With all the bouncing around on the highway the edge will act like a hacksaw against your straps. I towed my jeep down to Florida and when loading it up to head back home I discovered my rear LCA mount nearly sliced my axle strap in half. I was pissed cause I had just dropped a hundred bucks for these straps and now it isn't even a complete set. This might be common sense but just lookin out.
T_J is offline   Reply With Quote
Old September 17th, 2013, 09:56 AM   #26
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Originally Posted by T_J View Post
Joe,
How did you have the strap set up so it could get sliced by the LCA mount?
Old September 17th, 2013, 09:59 AM   #27
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Originally Posted by swampjeep View Post
what type/brand are you a dealer for? My straps are getting a bit worn,
I do Vulcan only just cause it's MI/Det made...
ReiKo is offline   Reply With Quote
Old September 17th, 2013, 10:01 AM   #28
ReiKo
ReiKo's Avatar
What's also nice about the Vulcan strap deal is it has a black mesh sleeve to go over the axle so it won't tear into the strap itself...
Old September 17th, 2013, 10:02 AM   #29
Coyote Red
Coyote Red's Avatar
I would also suggest getting a set of axle straps. They are about 12" long with closed metal lopps on both ends. I use them because I would rather grind mud and dirt into those than my actual straps when strapping around the axles . I use 4 2" 10k strap to on my F150.
Coyote Red is offline   Reply With Quote
Old September 17th, 2013, 10:07 AM   #30
howell_jeep
Last Free Man
howell_jeep's Avatar
Where can you buy axle straps?
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Old September 17th, 2013, 10:14 AM   #31
T_J
Make it or Break it
T_J's Avatar
I used to cross strap the rear on the outside of the LCA mount between that and the drum. Now i don't cross them, I strap right on the outside of the pig, on the drivers side you have to tuck the strap under a brake line and on the passenger side theres a small bracket on top the brake line I run it over top of. Then the front I cross strap though the knuckles.
Old September 17th, 2013, 10:16 AM   #32
silveradoboy
Sam Brown
silveradoboy's Avatar
The axle straps are really nice! Cam has them and it was really nice when strapping his jeep down
silveradoboy is offline   Reply With Quote
Old September 17th, 2013, 10:19 AM   #33
bbaXJ
Yooper In Training
bbaXJ's Avatar
I bought em at TSC for $9 apiece or so.
I also use 4 2" straps with the wire hooks on my rigs and have been very happy. Most of mine are actually from WalMart and have held up great. As far as I can tell, they're identical to what TSC sells. Next time around I may get something fancier, but I've had no issues with mine.
Old September 17th, 2013, 10:21 AM   #34
Timmy
Timmy's Avatar
I think I picked some up at Tractor Supply once.
Timmy is offline   Reply With Quote
Old September 17th, 2013, 10:26 AM   #35
DirtyMittenMudder
DirtyMittenMudder's Avatar
Home depot has 10k straps for $10 also.
DirtyMittenMudder is offline   Reply With Quote
Old September 17th, 2013, 10:28 AM   #36
DirtyMittenMudder
Yes TSC has them $10.
Old September 17th, 2013, 11:01 AM   #37
howell_jeep
Last Free Man
Thanks. My favorite store has them!
I SHOOT RAW!
Page generated in 0.40417 seconds with 73 queries
