Pressure tank loosing pressure - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2013, 08:52 PM   #41
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Originally Posted by MuddyPaws View Post
I would have to go outside and put my ear on the well head to hear it run I think. It's like way down in a hole. I never hear mine run. That's why I was asking.
If you go to your pressure switch you can hear it. The switch will click loudly with every cycle on or off.
ckupq is offline   Reply With Quote
Old September 16th, 2013, 09:31 PM   #42
This, and you will hear the sound of it running, transmitted through the pipes.
If there is NO water being used in the house, and the pump is cycling, then there's a leak.
If the pump cycles very fast when you are using water, that is short cycling, and is usually improper air setting in the tank, or a bad tank.
In either case, the well pump is turning on and off too much. The on and off is what wears out the pump. The best is a nice big tank that takes a long time to fill.
Old September 16th, 2013, 09:53 PM   #43
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Originally Posted by jeepfreak81 View Post
I thought he was Amish....
Hey, back on topic!
Old September 16th, 2013, 11:18 PM   #44
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by MonkeyBiz View Post
His, like mine has the pump down the well. I can't hear it when I'm outside, but I still easily hear mine kick on and off if there is water flowing when I'm inside. He didn't realize it wasn't supposed to do that. It wasn't until a friend of his came over, that he realized it. Silly city boy.
I have never heard mine cycle.
Hmmm.....never heard a switch click. Now i'm on a mission to find it.
Old September 16th, 2013, 11:42 PM   #45
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
How big is your pressure tank MP? Mine is small, so if I flush the toilet, it will kick on. My parent's is huge. You have to run the shower for 15 min before it turns on.
Old September 17th, 2013, 12:47 AM   #46
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
ok, first full disclosure. I'm a city boy. LOL Just moved into this house and never had a well before. Second, I know what a pressure tank looks like.
Do all well systems have a pressure tank? If this house has one, I can't find the damn thing.
Old September 17th, 2013, 01:11 AM   #47
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Yes. That's what keeps pressure in your system. It is usually right where the water line comes into the house. Think..utility room in the basement. If you don't have a basement, it's in the crawl space, or that goofy really small building in the back yard that the Realtor called a pump house.
I have seen/heard of them being in the attics, but that's usually in the south.
Go out side. Stand at your well. Find (what is usually) the shortest distance to the foundation. Then, go inside, and look in the area that you previously identified. It's usually in there. Unless you live in a mansion, they are kinda of hard to hide.
If all else fails, start tracing back water lines.
Old September 17th, 2013, 05:05 AM   #48
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Big Blue tank usually.
Old September 17th, 2013, 05:13 PM   #49
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
My new one is tan, my old one was red.
Old September 17th, 2013, 05:18 PM   #50
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
It can also be buried in the ground. The house we are buying has it buried next to the well. There is a second small (1/2"?) pipe coming up next to the well standpipe on ours, this has a valve like a bike tire for adjusting the pressure in the bladder. This was done in the 70's, then when you go inside the house all we have is a pressure switch where the water line comes into the house.
Old September 17th, 2013, 07:45 PM   #51
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I don't have one. Unless it's buried somewhere out in the yard. There is nothing in the basement.
Old September 17th, 2013, 08:11 PM   #52
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
That really surprises me... especially given you location. I can't imagine they would have put one outside that far north.
Are you sure your not on city water, and just have an old well in the back yard?
Old September 17th, 2013, 09:09 PM   #53
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
LOL
No, I live way outside the city. Well and septic. When we bought the house the PO explained how to change the pump if needed and had a receipt for a pump installed a couple years or so ago.
But I have looked all over the basement....finished basement. All the stuff down there is all in one room (furnace, water heater, central vac etc) and there is no tank in there.
I wonder if it's a long skinny one and it's in the drop ceiling.
Old September 17th, 2013, 09:17 PM   #54
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Are is there a water line running into the long skinny one?
Old September 17th, 2013, 09:36 PM   #55
jeepfreak81
81 inches of fun
LOL
Follow the water line where it comes into the house if you can. If it leads you to a pressure switch I bet the tank is in the ground someplace.
Did you have a well and septic inspection when you purchased the house, or any inspection? My inspector found all that and showed it to me.
Old September 17th, 2013, 10:10 PM   #56
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I don't know if there is a long skinny one. I was just pondering it that maybe it was in the drop ceiling. I'm too lazy to go that far looking for it. LOL
Old September 17th, 2013, 10:11 PM   #57
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Had an inspection but I wasn't present for it.
Old September 17th, 2013, 10:17 PM   #58
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
Originally Posted by HVYRTFT View Post
Ok great lakers
House is ten years old. The shallow well submersible pump is short-cycling because the pressure tank is loosing pressure. Here is what I know:
The tank's pressure is correct
2psi above/below what the pressure switch cuts in at? Or thereabouts? Depending on your well you may either want to keep some water in the tank (pressure lower than cut-in which is usually used with deep well/jet pumps) or use every less morsel of water you can store (pressure higher than cut-in which is usually used with shallow submersible pumps).
The pressure switch is functioning correctly
Are you sure? If the pump is fighting something when trying to fill the tank it will trip out prematurely. What I'm getting at, is if you have a 20gpm pump but can only get it to the tank at 5gpm the pump will build up pressure before the tank is filled.
Keep in mind that a pressure tank with a bladder rated at 42gallons only has ~6 gallon draw down at 30/50.
A water logged bladder tank (ruptured bladder) is probably the most common reason for pump short-cycling. They usually have a five year warranty because at 5 years and 1 day they poo the bed.
You can check them fairly easy. The easiest way is to look at the specifications of the tank and then use 5 gallon buckets to measure output.
No leaks in the house. No leaks in the copper.
Have you isolated everything? IE: turn off the valve between the well and the tank and the tank and the house to isolate where the water is going?
There is NOT a check valve right where the water supply enters the building.
I am assuming there is one somewhere I cannot get to without pulling the well pump.
You just need one somewhere if you have a submersible pump. Doesn't really matter where but preferably before the pressure tank and the pressure switch. Unless you buy an expensive check valve (think $200+) there will be significant pressure loss across the valve (like 5psi at 5gpm). The pump is sitting in a well casing so sinkholes don't make sense unless your pulling sediment out of the well.
I'm guessing the water or air is flowing back into the well.
Is my tank bad or the check valve on the well side bad?
It's quite possible that water is flowing back. I lose pressure over the course of a couple days because I have a bad check valve and my dishwasher leaks (lets air in to the hot water side). I have a cheap check valve that is severely oversized in an attempt to avoid paying a lot for something that doesn't restrict flow. I bought it over a year ago and still haven't put it in.
My pump puts out about 17gpm. It cycles in roughly 30 seconds to go from 50psi and turns off at 76psi. I have another 82 gallon equivalent to 35 gallon tank that I have to put in. In theory, that will give me about a 15 gallon draw down between the two tanks.
I do have a disclaimer... I'm fairly new to this. I'm used to nursing along a 240' well that flows roughly .75gpm through a 2" pipe. I now have a 5" well 43' deep with the pump at ~25' and water at 14'.
wrath is offline   Reply With Quote
Old September 17th, 2013, 10:37 PM   #59
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I found the damn thing. It's built into the bottom of a shelving unit in my gun room.
Old September 17th, 2013, 10:57 PM   #60
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
I have this mental video in my head of you reading about his on GL, thinking hey, where is mine? Then, in only your underwear, (tighty whities ) frantically searching, getting frustrated, drinking a beer, and another and another until your drunk. Waking up at 4 am hungover, confused why your in your basement in your underwear, seeing the lap top open, remembering and continuing the frantic search. Finally, after 30 hours of searching, drinking, passing out, waking up, drinking (repeat) you approach your gun cabinet, tired, drunk (again) ready to rip the fucker out of the wall. Then you open a cabinet door, and lights shine on it, and holy music plays. You've found your holy grail. Congratulation.
I have a vivid imagination.
Page generated in 0.56836 seconds with 82 queries
