8.8 hung disc brake - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 14th, 2013, 10:39 PM   #1
Trendsetter
Trendsetter's Avatar
Send a message via AIM to Trendsetter Send a message via Yahoo to Trendsetter
Default 8.8 hung disc brake
Ok so like the title says I am fighting with a rear axle rotor that won't come off. I have done heat I have hammered on both sides and am even attempting to do this http://youtu.be/mtsTJCRljAs it appears the rotor is stuck to the axle shaft end. I am losing my mind right now any hints tips and tricks would be great.
Trendsetter is offline   Reply With Quote
Old September 14th, 2013, 11:25 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Mix ATF and acetone 50/50 in a squirt bottle. Drench it down and let it sit. That is the best penetrant I have ever used. It may do nothing but it won't hurt.
Old September 15th, 2013, 01:00 AM   #3
built
built's Avatar
What did you use for heat? Propane/butane alone would take forever to heat it up. Oxy/acy or oxy/pro and a hammer used properly to heat the correct area will have it off in no time
built is offline   Reply With Quote
Old September 15th, 2013, 11:29 AM   #4
yyj87
yyj87's Avatar
Get it hot, we want the rotor to heat up drasticly quicker than the axle shaft.
Mapp will work if its not to bad, sounds like you need big boy torches.
yyj87 is offline   Reply With Quote
Old September 15th, 2013, 12:36 PM   #5
GREASYHANDS
GREASYHANDS's Avatar
Loosen the parking brake
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old September 15th, 2013, 08:07 PM   #6
Bjones
Bjones's Avatar
Spray on Coppertone sunscreen. It works surprisingly well. Spray it on and let it set a couple of minutes then pop it off
Bjones is offline   Reply With Quote
Old September 15th, 2013, 09:26 PM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
If it's hanging on the the parking brake, cut the pins that hold the shoes to the backing plate.
Old September 15th, 2013, 10:36 PM   #8
Trendsetter
So it was not hanging up on the parking break since I never re installed them. However that video I posted did the trick in under 20 minutes both sides were off. Grade 8 bolts 1/4 x 20 bolts and a ton of washers. Pro tip make sure you put a lug nut on or the rotor will go flying!!
Page generated in 0.30695 seconds with 47 queries
