1997 dodge cummins stuck in limp mode - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 13th, 2013, 05:27 PM   #1
its a morey thing
its a morey thing's Avatar
Default 1997 dodge cummins stuck in limp mode
takes off in 2nd gear you can pull to first and it will shift down but if you try to shift to 3rd its like hitting neutral. replaced speed sensor changed nothing and to top it off i have no obd2 connector it was never installed when they did the cummins swap
its a morey thing is offline   Reply With Quote
Old September 15th, 2013, 06:52 PM   #2
Jordank520
Jordank520's Avatar
might be the gov pressure sensor and solenoid in the trans. mine used to start off in 3d if left in drive, but you could manually shift. It never acted like neutral when it wanted to shift to 3rd, it just would never shift and keep reeving.
Jordank520 is offline   Reply With Quote
Old September 18th, 2013, 09:03 AM   #3
Lousypirate
Whoop Whoop
Lousypirate's Avatar
assuming it is an auto?
12 valve shouldn't have obd2 since there isn't a computer...
Do you think it is trans related, or motor related?
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old September 19th, 2013, 09:50 PM   #4
88yjproject
It is either the governor solenoid and transducer or your kick down cable is not adjusted properly/ wore out.
88yjproject is offline   Reply With Quote
Page generated in 0.22260 seconds with 35 queries
