Cam selection - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2013, 05:01 PM   #1
davidkassie
davidkassie's Avatar
Default Cam selection
building a pretty healthy 406 for my mud truck, any suggestions on camshaft selection criteria?? as far as truck cams/race cams/etc... should it be like a circle track grind? maintaining pretty high rpm instead of a "rpm range"... little input from some veterans would be appreciated! thanks, david
davidkassie is offline   Reply With Quote
Old September 11th, 2013, 05:14 PM   #2
GearDrive
A little slow
GearDrive's Avatar
Needs to be matched with other components. Compression ratio, intake, transmission, axle ratio, ect.
GearDrive is online now   Reply With Quote
Old September 11th, 2013, 05:19 PM   #3
davidkassie
I know that.. lol. just curious if anyone had experience with any cam selections being better than others for mud trucks..
Old September 11th, 2013, 05:30 PM   #4
Coyote Red
Coyote Red's Avatar
I would play around with Comp Cams' Cam Quest program. It will give a paper idea of what combination will produce what results.
Coyote Red is offline   Reply With Quote
Old September 12th, 2013, 11:07 AM   #5
in2deep
Hole tester
best to talk to comp cams or crane and ask them. and a circle track cam would suck they don't make low end power. converter specs will also have a huge effect on cam choice
Old September 12th, 2013, 11:20 AM   #6
Iggy
Iggy's Avatar
Comp Cams does have some grinds they claim are for Mud Trucks, might want to look at that. General rule of thumb, mudding is acting more like a Bracket Racer than a Circle Track racer - you should be looking at Drag Race cams, exact cam will depend on weight, gearing, tire size and compression.
Iggy is offline   Reply With Quote
Old September 12th, 2013, 11:20 AM   #7
frdboy
frdboy's Avatar
Nothing really different, still want the most ave. HP over the intended RPM range.
Old September 12th, 2013, 11:36 AM   #8
3 / 4 race!!!!!!!!!!!!!
Old September 12th, 2013, 11:37 AM   #9
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Someone is dating themselves!
Old September 12th, 2013, 11:38 AM   #10
Sure
Old September 12th, 2013, 11:42 AM   #11
frdboy
frdboy's Avatar
Page generated in 0.26655 seconds with 56 queries
