Barnes 4WD Toyota Differential Cover - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vendors
Vendors Companies That Deliver Great Products Or Services and a list of companies offering GL4x4 Discounts
Thread Tools
Old September 11th, 2013, 12:30 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Barnes 4WD Toyota Differential Cover
Barnes 4WD is proud to introduce the first Toyota Diff Cover that offers complete protection for your third member, maximizes clearance and increases fluid capacity. This cover is not your typical cap that you just weld over the thin stock housing. With our cover you completely remove the factory cap (a quick job with a cut off wheel) and weld a laser cut and bent " A50 Plate Steel cover in its place. This is a little more work but the payoff is worth it for the total coverage and increased oil capacity. This cover will fit front and rear Mini Truck and 4 Runner axles, IFS rear axles and even Toyota Tacoma axles with a TRD E-Locker. Covers ship fully welded with a large fill plug so all you have to do is prep your axle and weld it on!
They cost $60 and can be found here:
Barnes 4wd is offline   Reply With Quote
Old December 8th, 2013, 12:19 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Our Toyota differential cover is a great way to increase the strength of your 8 inch axle at a great price:
Old July 21st, 2014, 04:12 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
Our Toyota Differential Cover is made of high quality, USA made A50 steel and built to last. If you need a quote email us at Sales@Barnes4wd.com.
Thread Tools
Page generated in 0.20498 seconds with 32 queries
