Vintage johnson parts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2013, 10:38 PM   #1
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
Default Vintage johnson parts?
I am repairing a 1955 johnson 5.5 model cd-12 that has been in the family since new. I'm in need of the bearing plate that goes in the lower section underneath the impeller housing. It's a discontinued part so I am looking for a used one. Anyone know of a good source for vintage used parts?
Sent from my GT-P5113 using Tapatalk 2
Old September 10th, 2013, 11:46 PM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I would contact Johnson, out whoever bought them out (evinrude?)
I contacted ranger about my 77 bass boat and they supplied me with a lot of information really quickly. I'll be asking them more questions once I tear into her this winter.
Old September 11th, 2013, 12:03 AM   #3
kkodet
kkodet's Avatar
I bought some parts on ebay, and lgottler here on the board machined some others for me, for my old early 70's model.
Old September 11th, 2013, 12:57 AM   #4
tom77cj5
tom77cj5's Avatar
Marineengine.com has a lot of nos stuff did you look there? Just rebuilt my 76 40hp all with parts from them
Old September 11th, 2013, 10:08 AM   #5
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
I had contacted evinrude and marineengine and no go I'm still scouring around and found a couple of used ones but they are $$$$ I may have no other option.
Old September 11th, 2013, 10:15 AM   #6
Lousypirate
Whoop Whoop
If you have it pulled out, you can probably have a machining facility make one (or two) and get it to fit the bearing plate and whatever else the attachment points are?
Old September 11th, 2013, 10:29 AM   #7
howell_jeep
Last Free Man
howell_jeep's Avatar
Would parts from evinrude fleetwin 7.5 work on your engine? I'm not sure what year it is, but I think they made them in the 50's.
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Old September 11th, 2013, 02:49 PM   #8
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
I could and it's out but I think it would cost more to machine it than it would to find one used. I can't understand why this part isn't made anymore. Common fail part. This part goes under the impeller wear plate and seals the upper gear case. Attached is a pic, there is a brass bearing in there and some machining on the other side and place where the driveshaft grease seal goes.
This image is the bottom of the part.
Old September 11th, 2013, 02:55 PM   #9
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
yes, but it is the same part # for both motors. the bearing plate can come out of any 55-64 5.5 horse johnson/evinrude.
Old September 11th, 2013, 03:00 PM   #10
Lousypirate
Whoop Whoop
depending on what's worn, couldn't you have the material built back up and machined away?
Old September 11th, 2013, 03:09 PM   #11
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
Unfortunately it's cast aluminum. the upper pinion shaft on these is a two piece design with a spring shock absorber in it. The spring breaks, then rotates and pushes that bearing plate up breaking it. it's bolted to the lower housing and since that flat section is so thin, it warps and cracks them badly. I've welded the upper pinion shaft into one piece, but it will do nothing but leak if this plate isn't true. If the part was made out of billet it would probably not get damaged so easily. I am going to put a soft shear pin in the prop instead of the factory steel. I can buy a complete lower gearcase, but I'll end up with a whole lot of stuff I really don't need.
Here's a photo (not mine) that shows the topside of the plate
Old September 11th, 2013, 04:02 PM   #12
Outdoors
Field Repairs
Outdoors's Avatar
Brians Marine, Benton Harbor, Michigan (269) 983-0760. I rebuilt a '57 7.5 last year, and he was able to locate all but one part that I needed, and it was just a trim piece. Seeing how you have the pictures, I am guessing that you can also doe the homework of getting the part number. I provided him with the numbers off the internet, and he located the parts. He had everything that I needed in in less than two weeks.
Outdoors is offline   Reply With Quote
Old September 11th, 2013, 04:12 PM   #13
Wheelman
Extreme Mudder
Wheelman's Avatar
http://www.vanssports.com/
One of the largest inventories of obsolete and rare parts. They had NOS electric shift magnet for my 1966 80hp V-4.
Wheelman is offline   Reply With Quote
Old September 11th, 2013, 04:51 PM   #14
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Sports fishermen. Boat shop in Muskegon with has alot of old parts/conections
Old September 11th, 2013, 06:19 PM   #15
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
Thanks guys. I will check out these leads!
Old September 11th, 2013, 06:41 PM   #16
Trail Junkie
iamfawkinwithyou
Ask for mike
Page generated in 0.29562 seconds with 72 queries
