08 Mariner (ford escape) left bank lean code - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2013, 08:33 PM   #1
CB10101
CB10101's Avatar
Default 08 Mariner (ford escape) left bank lean code
My wife's 08 Mariner, 3.0l v6, 126k miles just threw a left bank lean code after rough idle and hesitation.
I put a bottle of f/i cleaner in the tank and took it for a 20 mile drive. Came home and unhooked the battery to clear the code. Seemed to work fine for a couple hours then started up again.
Since only the left bank is showing a lean condition, could it be a bad injector or o2 sensor?
All equipment is original except for the Alternator which was changed last week.
CB10101 is offline   Reply With Quote
Old September 10th, 2013, 10:14 PM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
3 liter was common for intake gaskets i believe, and that would cause a lean code.
booblinker is online now   Reply With Quote
Old September 10th, 2013, 11:39 PM   #3
Toyfish
Toyfish's Avatar
Ford had a issue with a vacuum line on the back pf the 3.0 intakes
Sent from my DROID X2 using Tapatalk 2
Old September 11th, 2013, 06:27 AM   #4
frdboy
frdboy's Avatar
X3, probably a vac leak somewhere. check the PCV/breather hoses, they get oil soaked and sucked in.
Old September 11th, 2013, 06:48 PM   #5
CB10101
CB10101's Avatar
Thanks all, i checked the vac lines and pcv valve which seemed fine. Listened for vac leaks and finally gave in and took it to the dealer. Ended up being a dirty maf sensor. Last oil change i didnt seat the air filter properly and some bugs got caught in the sensor. $99 mistake.
Page generated in 0.21688 seconds with 38 queries
