windshield removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2013, 06:39 PM   #1
caveman
GeoDude
caveman's Avatar
Default windshield removal
Anyone remove one before without special tools? Just picked up a xj that's going to be a trail rig and I'm not gonna pay to have it done. Was thinking a butter knife and a thin long wire.
Old September 10th, 2013, 06:43 PM   #2
kkodet
kkodet's Avatar
Old September 10th, 2013, 06:50 PM   #3
caveman
GeoDude
caveman's Avatar
and thats why it needs replaced
Old September 10th, 2013, 08:38 PM   #4
yyj87
yyj87's Avatar
I have done it successfully with picture wire and a razor.
It took forever and I will never do it again.
yyj87 is offline   Reply With Quote
Old September 10th, 2013, 08:41 PM   #5
skife
skife's Avatar
http://www.harborfreight.com/windshi...ool-99892.html
Old September 10th, 2013, 09:17 PM   #6
caveman
GeoDude
caveman's Avatar
damn. Thats cheap enough to do the trick.
Old September 10th, 2013, 09:18 PM   #7
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Guitar string works great.
Old September 10th, 2013, 09:26 PM   #8
Mclovin
"The Situation"
Mclovin's Avatar
this ! or piano wire.. with handles on each end!
That tool listed is junk ! I used one and the blade folded as soon as i put pressure on it..
if you dont mind a huge mess you can sit in the front seat and push with your feet but you'll still have to cut out the edge with a utility knife
Old September 10th, 2013, 09:41 PM   #9
fordbronco
the ocean called
fordbronco's Avatar
Duct tape and sledgehammer
Old September 10th, 2013, 09:48 PM   #10
BlooMule
Old School
BlooMule's Avatar
7.62x39
-rw-rw-rw
Old September 10th, 2013, 11:04 PM   #11
kkodet
kkodet's Avatar
In all honesty the tool works good. A good trick is to heat the blade till it is red hot before cutting into the rubber.
Old September 11th, 2013, 01:05 AM   #12
tom77cj5
tom77cj5's Avatar
When my buddy did windshields he had a scrapper looking attachment for a fancy looking sawsall that he used and went around the inside perimiter cutting the glue. Took like 3 minutes to take out the window
Old September 11th, 2013, 01:18 AM   #13
I suck cocks. Lots of them.
locally famous
i use a sawzall with a long blade. use the tip of the blade to cut into it, and run it backwards to avoid cutting into sheetmetal. way easier then piano wire, or a hood latch cable. i have done this a lot.
Old September 11th, 2013, 09:25 AM   #14
firehawk
Live Action!
firehawk's Avatar
So easy a caveman could do it.
Old September 11th, 2013, 10:48 AM   #15
86scottsdalek10
86scottsdalek10's Avatar
Some of these guys are on target. I did windshields for a while. Use a single strand guitar wire or something comparable with handles or get a $1 paint scraper from your local hardware and remove the handle. Insert it into say a 24" long pipe from same hardware store and hammer the pipe flat to hold it. All it takes is some soapy water sprayed along the whole inside edge on the urethane and you can use your hammer to remove the whole windshield with that tool without damaging the paint
Similar to what Tom has described but just a manual version. Used to use it on customer windshields for difficult corners. We called that sawzall the "spatulator" $800 for that thing!
86scottsdalek10 is offline   Reply With Quote
Page generated in 1.07983 seconds with 69 queries
