The Enduro Joint from Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 10th, 2013, 05:05 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default The Enduro Joint from Barnes 4wd
Barnes 4wd - Enduro Joint
We recently switched from using a spanner nut system to a new more durable snap ring system!
When Barnes 4WD designed the Enduro Joint we combined the best materials, the best manufacturing processes and the best steel and polyurethane treatments available all in one joint.
The body of the Enduro Joint is Forged 4140 heat treated Chromoly steel. We did not try to cut any corners by making a short threaded shank like a heim joint instead we give you 3.25” of 1.25-12 threaded shank.
That is over one inch longer than 1.25” heims on the market. The Enduro Joint’s ball is made from 52100 bearing steel and incorporates the high misalignment spacers all into one piece of steel that provide 40 degrees of misalignment. Forty degrees of misalignment will net almost 33” of travel on a four foot control arm.
The spherical bearing is then Hard Chrome plated to provide an ultra smooth surface and has proven to provide excellent corrosion protection. The mounting width of the Enduro Joint is 2 5/8” and has a 5/8th or 9/16ths inch bolt hole.
The cups that the spherical bearing rides on are an 88 durometer polyurethane that ensures maximum life, no squeaks like heim joints and they help to dampen axle vibrations felt through the chassis.
The body of the joint is gold zinc plated to ensure that the Enduro Joint looks great for the life of the joint. Once the joint is fully assembled we are still not finished making the ultimate joint. Every completed Enduro Joint assembly is then Cryogenically Treated to give the Enduro Joint the most strength and greatest wear characteristics possible.
They can be found in both LEFT and RIGHT threads with both 5/8th and 9/16th inch bolt holes here:
Barnes 4wd Enduro Joint
Barnes 4wd is offline   Reply With Quote
Old November 6th, 2013, 01:30 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
We have plenty of these joints in stock. If you are running them then post up some photos on our facebook or in this thread!
Old November 15th, 2013, 03:15 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
Here is a build that Luke at Hazzard Fab Worx has been working on. He built a custom front and rear link suspension using Enduro Joints.
Old February 1st, 2014, 02:18 PM   #4
Barnes 4wd
Barnes 4wd's Avatar
These joints are a great value, and always in stock. Let us know if you have any questions or need help finding the correct brackets to use with the Enduro Joint. Remember they come in both left and right hand threads!
Old April 19th, 2014, 02:04 PM   #5
Barnes 4wd
Barnes 4wd's Avatar
The Enduro Joint is still only $47.90 and is fully rebuildable!
They are perfect for building your own suspension, or upgrading a current worn out bushing or joint.
Old August 2nd, 2014, 05:41 PM   #6
Barnes 4wd
Barnes 4wd's Avatar
Barnes 4WD Enduro Joints are always in stock and always ready to ship out to you!
Find the Enduro Joint and all the parts to rebuild it HERE.
Old October 10th, 2014, 03:22 PM   #7
Barnes 4wd
Barnes 4wd's Avatar
The Barnes 4WD Enduro Joint gives you 40 degrees of misalignment. Here are a few pictures from our customers showing what you can do with them:
Find our joints online, here.
Old December 18th, 2014, 02:51 PM   #8
Barnes 4wd
Barnes 4wd's Avatar
Bumping this back up, we have plenty of our Enduro Joints in stock! Who else has pictures of our Enduro Joints in use?
Old March 5th, 2015, 05:24 PM   #9
Barnes 4wd
Barnes 4wd's Avatar
Barnes 4WD Enduro Joints being used in a triangulated 4 link suspension by one of our customers:
Check out more pictures of the joints in use, and share your own photos on our Facebook page. You can purchase Enduro Joints on our website and find more information about them here.
Old April 26th, 2015, 05:01 PM   #10
Barnes 4wd
Barnes 4wd's Avatar
Bump! Check out our Enduro Joints, Heims and Hardware for all the different options we stock.
Old June 22nd, 2015, 02:16 PM   #11
Barnes 4wd
Barnes 4wd's Avatar
Enduro Joints are always in stock!
Old July 19th, 2015, 10:43 PM   #12
Barnes 4wd
Barnes 4wd's Avatar
Check out our Enduro Joint Spanner Wrench, perfect if you ever need to rebuild a joint:
Old September 2nd, 2015, 12:45 AM   #13
Barnes 4wd
Barnes 4wd's Avatar
Old September 2nd, 2015, 09:57 AM   #14
knixon804
THE GENERAL
knixon804's Avatar
Why? No pre load adjustment
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Thread Tools
Page generated in 0.45062 seconds with 65 queries
