Barnes 4wd SQUARE tube inserts - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 9th, 2013, 06:51 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Barnes 4wd SQUARE tube inserts
Barnes 4wd Square tube inserts for 1.25-12 and 7/8-14
Barnes 4wd Square tube inserts will help you keep the overall cost down on your link project. Tube inserts for square tubing do cost a little more to make but, the cost of square tubing verses round DOM can save you as much as half on the cost of material.
These square bungs will fit into a square material that has a 1.5 ID. Tube adapters are a basic necessity for every DIY Fabricator. No matter if you are building a four link set up for you new rock crawler or you own heavy duty steering linkage for your trail rig you have to have them. These weld in inserts make it easy to fabricate adjustable linkages. All of our tube inserts are CNC machined.
Barnes 4wd is offline   Reply With Quote
Old November 20th, 2013, 01:20 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Combine these inserts with our Enduro joints, brackets, and some tube from your local supplier to build a heavy duty link suspension!
Old April 23rd, 2014, 10:00 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
These tube inserts work great with our Enduro Joints or Heim Joints to build yourself a strong suspension on the cheap!
Visit our website for more info or to contact us!
Old March 27th, 2015, 07:58 PM   #4
Barnes 4wd
Barnes 4wd's Avatar
Bumping this back up. Square tube inserts are always in stock!
Thread Tools
Page generated in 0.22326 seconds with 35 queries
