Barnes 4wd 3/8" Differential Covers! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 8th, 2013, 05:45 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Barnes 4wd 3/8" Differential Covers!
All Barnes 4wd Differential Covers are laser cut and bent in a state of the art CNC Press Break. The entire cover is made from 3/8" US Steel and we GUARANTEE THEM FOR LIFE. All cover are fully welded and machined flat and the threaded fill plug is TIG welded in place. These covers are made to withstand the hardest conditions. Like all our products they are made in the USA.
Barnes 4WD GM 14 Bolt High Clearance Shave Cover
The 14 bolt is a great axle. They are cheap, strong, easy to find and cheap to build. However they have always had one down fall, that huge lip on the bottom that get hung one ever thing on the trail. Barnes 4WD has come up with a solution to this issue. Our GM 14 Bolt 3/8” Shave Cover. This cover will give you more than 1 ¼” of ground clearance. Another thing that makes this a great shave cover is that you will not need to have your gears turned or perform a complicated welding or machining process that just adds more cost to your axle build. All that you will need to do is bolt the diff cover to your axle and cut off the extra lip. This can be done with simple tools that you have and you can do it yourself and we GUARANTEE THEM FOR LIFE! Like all of our diff covers they are made from 3/8” plate and machined flat after they are welded to insure that you will have a flat surface to mount to your axle. We do recommend using allen head bolts on our GM 14 Bolt Shave Cover.
Barnes 4wd is offline   Reply With Quote
Old October 24th, 2013, 11:46 AM   #2
Barnes 4wd
Barnes 4wd's Avatar
You can find these online, or give us a call with any questions!
Old November 24th, 2013, 07:29 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
You can find all our differential covers HERE. Shipping is fast and easy. If you have any questions let us know!
Old April 26th, 2014, 07:11 PM   #4
Barnes 4wd
Barnes 4wd's Avatar
In addition to our bolt on differential covers, we have a weld on cover for the Toyota 8" that allows you to maximize your fluid level and strength:
This cover is made of 1/4" A50 plate steel, all our other covers are 3/8th inches thick!
Find all our differential covers under the Axle Accessories section on our website.
Old June 19th, 2014, 12:39 AM   #5
Barnes 4wd
Barnes 4wd's Avatar
Check out this D30 cover that one of our customers installed:
Our covers are made from 3/8ths inch USA steel and built to last!
Old October 7th, 2014, 08:36 PM   #6
Barnes 4wd
Barnes 4wd's Avatar
We've recently added a few more Toyota differential covers to our site:
Toyota 07+ Tundra HD Differential Cover
Toyota T100, 1996 and Newer Tacoma and 99-06 Tundra HD Differential Cover
Toyota Pick Up HD Differential Cover
We also build a 3/8ths inch bolt on cover for these axles:
Dana 30
Dana 35
Dana 60 & 70
14 Bolt
Old May 15th, 2015, 12:04 AM   #7
Barnes 4wd
Barnes 4wd's Avatar
Add an extra layer of protection to your rig’s underside with a heavy duty 4WD differential cover from Barnes. Made from 3/8" USA Steel for bolt on covers, ¼” steel for weld on Toyota covers and guaranteed for life! These covers are made to withstand the harshest conditions.
Check them all out:
Barnes 4WD Differential Covers
Thread Tools
Page generated in 0.18660 seconds with 44 queries
