95 dodge ram trans issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2013, 01:18 PM   #1
chevybtk
~~1995 chevy k2500~~
chevybtk's Avatar
Question 95 dodge ram trans issue
I have a 95 ram with a 5.9l 4x4 went trail cruising not real muddy now trans doesn't want to shift out of 2nd gear what could be issue reverse works great as well as 1st to 2nd is ok...any ideas?
chevybtk is offline   Reply With Quote
Old September 9th, 2013, 05:57 PM   #2
74_jeep
74_jeep's Avatar
Check the linkage ,my 96 did that and the linkage from the passing gear rod was sticking.
74_jeep is offline   Reply With Quote
Old September 10th, 2013, 07:57 AM   #3
redramman
redramman's Avatar
Did wetter get in trans? Check linkage.I put a small return spring on my kick down/ throttle position lever at trans the little holes to mount it were already there, got springs from hardware store put little one inside other spring like carb spring.
redramman is offline   Reply With Quote
Tags
wat?
Page generated in 0.26606 seconds with 32 queries
