The Yerf Dog GX150 build - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 14th, 2013, 11:36 PM   #21
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
So far, I changed the oil, lubed the chain, cleaned it up, moved the lights up to the top, re did the rollbar padding, and am in the process of re-locating the battery(s).
Oh yeah, couldn't forget the dune flag. ;)
It turns out the previous owner replaced the front end after the buggy hit a tree, but some of the parts he got were wrong. He has uneven a-arms with even spindles, so I went ahead and ordered a set of longer a-arms to work with the spindles I have. I also ordered a set of 4x4 hubs, wheels+ atv tires for the front.
Since finding the stock air filter for the engine wasn't too easy, I also ordered a UNI filter kit .
Tonight I began the battery relocation process. The previous owner had been using one of these 12v gel cell batteries to start the kart. He also gave me an extra one. So I decided to use both onboard and wire them in parallel to double my capacity. I am relocating them inside a plastic electrical box on the rack.
I wanted the extra capacity, because I'm going to hook up a radio in the kart:
Old September 17th, 2013, 08:06 PM   #22
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Wired in a switch between the two batteries after reading about wiring them parallel. Apparently if one of the batteries is a little older, it can cause the other battery to go bad faster. So, to keep this from possibly happening, and to have a back up battery onboard just in case I drain it with the radio or lights, I went with the switch.
I also added some finger twist knobs to make the box quick release.
Old September 17th, 2013, 08:10 PM   #23
Lousypirate
Whoop Whoop
Lousypirate's Avatar
you might want to check the amperage capacity of the switch... if you haven't already. Not trying to belittle you, but i didn't see anything posted so I'm gonna raise the question.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old September 17th, 2013, 08:28 PM   #24
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
The batteries are 7 amp. The switch was rated at 20 amp @ 250v.
Old September 18th, 2013, 07:43 AM   #25
Lousypirate
Whoop Whoop
I'll shut up now.
Old September 18th, 2013, 08:50 AM   #26
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
I'll shut up now.
lol. It's fine. I might have said the same thing, but its a heavier switch and the batteries are pretty small, so it should be fine. I thought about putting one of those big battery cut off switches on it, but I didn't feel like shaping the hole to mount it flush on the outside of the box. :)
Old September 18th, 2013, 08:55 AM   #27
Lousypirate
Whoop Whoop
I guess the only other thing I would mention is puttins something over the terminals so you don't accidentally short them out. spark plug boot?
Old September 18th, 2013, 08:59 AM   #28
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Not a bad idea. I'll have to look into that.
Hopefully some of the new toys for it come in today. :)
Old September 18th, 2013, 04:44 PM   #29
stereoguy
2jz NO SH*T!
stereoguy's Avatar
By the way . I like the go-cart it looks fun !
stereoguy is offline   Reply With Quote
Old September 18th, 2013, 05:14 PM   #30
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Spending money on a go cart or riding a moped?
Old September 18th, 2013, 09:22 PM   #31
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
huh?
I don't have a moped anymore, although I was looking for one as a project. I found this instead.
The current 2 wheeled contraptions in my garage are:
2005 Yamaha FZ6
2009 Kawasaki KLX250s
2005 Yamaha TW200 (might as well be a moped, but it's my wife's)
1972 Yamaha R5
Old September 18th, 2013, 10:00 PM   #32
L4CX
Out for the Summer!
L4CX's Avatar
We had 5 or 6 of those one summer at camp. Just one summer
We also ran them 3 to 12 hours a day pretty Much.
Beef up the front, I believe we replaced (or welded) every single spindle at some point.
Keep the engine oiled up, you should ne fine.
I can't remember anything else we encountered that wasn't because of daily beatings.
Looks like a fun project.
L4CX is offline   Reply With Quote
Old September 18th, 2013, 10:11 PM   #33
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
I ordered the heavy duty top a-arms. If the spindles break, I'll just have a grade 8 bolt welded in. I don't think we'll be too rough on it.
Why only 1 summer?
Old September 18th, 2013, 10:25 PM   #34
L4CX
Out for the Summer!
L4CX's Avatar
Why only 1 summer?
That's as long as they lasted. We bought new ones the next year. Those lasted 2 summers. We don't have go carts anymore. We probably have close to 15k (very conservative guess) people use our facilities, including activities, from June to August.
Old September 19th, 2013, 01:53 PM   #35
ZJeepMI
ZJeepMI's Avatar
huh?
2005 Yamaha FZ6
1972 Yamaha R5
Hey now! The TW is a perfectly capable small motorcycle, I just rode mine to gladwin from plymouth a few weeks ago, and it's a tank on the trail. Just reeeeeaaally slow above 55 Definitely not a moped!
Cool go kart thing though, I always thought they looked like fun.
ZJeepMI is offline   Reply With Quote
Old September 19th, 2013, 03:58 PM   #36
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Thanks.
I really like the T-dub. I just wish it had a little more pep. I really would like to ride a new one to compare to hers. A TW350 would be sweet.
Old September 25th, 2013, 02:41 PM   #37
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Here's some shots:
Finally the front end seems to be coming together.
I mounted the radio in waterproof outdoor products box that I use for kayaking .
I mounted a couple "tool tubes" to the top bars to store tools/extra fuel in. I am also a member at ADVrider.com and got the idea from there.
The Uni Filter and the "performance" 30mm intake. Does anybody know if it actually makes much of a difference? I just got it because it was aluminum and it shouldn't crack.
Just waiting for tars. :)
Tires came in today:
I just need to grab an ORV sticker and I'll be in business.
Old September 25th, 2013, 03:20 PM   #38
Denton
Brush Yo Teeth!
Denton's Avatar
I like it! Nice job
Denton is offline   Reply With Quote
Old September 25th, 2013, 03:29 PM   #39
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Let me make sure I got this right... you have fuel stored on top of the roll cage, on the outside of it, where you would land if you roll over... and trees can smack it while driving down trails... and in a re-purposed storage device.. and you and your wife sit under it... and it's above the exhaust... so if it leaks it would drop on to that...
I believe Darwin is calling. He has an award for you.
Old September 25th, 2013, 04:11 PM   #40
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Actually at the moment, there is nothing in them. I will be using a MSR fuel bottle that is rated for fuel or I may not store any fuel in them and keep a 1 gallon gas can on the rear rack depending on how much fuel it consumes. I don't plan on doing anything where I would come close to rolling over. Its for driving down two tracks and county roads.
Also, as I look around my garage, all of my bikes seem to have their fuel tanks precariously above the header pipes. Holy shit, I've got a garage full of death traps!!!
Wife approved!
action shot!
Page generated in 0.45329 seconds with 83 queries
