Chernobyl Cherokee - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 6th, 2013, 11:56 PM   #1
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
Default Chernobyl Cherokee
ive been on this forum quite a while... finally decided to make a build thread.
the jeep has gone from a clean rig to a beater. but she loves it. originally a VA jeep, so its super clean underneath. here are some mile marks from the years...
originally...
4.0/AX15/231
D30/8.25 with 3.07s
RE 4.5" super flex lift
judgement day...
back home on the east coast...
VAhasnoWAVES is offline   Reply With Quote
Old September 6th, 2013, 11:59 PM   #2
VAhasnoWAVES
Dirty South
then i moved to Mi to go to school (fire up chips!) and got carried away a little...
before:
After:
she used to be so clean...
Old September 7th, 2013, 12:04 AM   #3
VAhasnoWAVES
Dirty South
my first real wheeling trip was to rocks and valleys... have loved that place ever since.
so i went back...
Old September 7th, 2013, 12:08 AM   #4
VAhasnoWAVES
Dirty South
jeep blessing... 2011?
back to rocks and valleys that fall
picked up some moabs and threw 3.55 geared axles under it.
Old September 7th, 2013, 12:14 AM   #5
VAhasnoWAVES
Dirty South
rocker pannel 2x6x1/4" replacement
hack and tap
started playing in the rocks a little
then this happened
picked up some 285s
Old September 7th, 2013, 12:18 AM   #6
VAhasnoWAVES
Dirty South
goodies over the years
Old September 7th, 2013, 12:23 AM   #7
VAhasnoWAVES
Dirty South
went back out and played some more...
some winter fun
this happened...
Old September 7th, 2013, 12:30 AM   #8
VAhasnoWAVES
Dirty South
started a fun little project that i have dubbed the "dana 34.W"
WJ knuckles...
machined them to accept D44 brakes/hubs
perfect
playing on the toys at work
picked up some steering and new trackbar... DIY style...
Old September 7th, 2013, 12:33 AM   #9
VAhasnoWAVES
Dirty South
jeep blessing 2013
Old September 7th, 2013, 12:38 AM   #10
VAhasnoWAVES
Dirty South
got a good trade and stepped back to 15... wanted them for my 34.W swap
had some custom jeep stuff made
she stands real good now...
Old September 7th, 2013, 12:42 AM   #11
VAhasnoWAVES
Dirty South
installed a rear spartan then it was back to rocks and valleys!
let my roomate drive
long crawl
had to get tugged the last 20ft
Old September 7th, 2013, 12:44 AM   #12
VAhasnoWAVES
Dirty South
that last wheeling trip ruined 3 of my 4 tires, and i was tired of running other peoples garbage... so i splurged
35s
Old September 7th, 2013, 12:48 AM   #13
VAhasnoWAVES
Dirty South
as you can see... shes had kind of mutated over the years towards ugly, hence the name "chernobyl"
as she sits now:
RE 4.5" super flex kit
HD Offroad shackle relocation brackets
BPEs, RE monotubes
ZJ steering
hack and tapped 231
3.55 geared axles
aussie front, spartan rear, riddlers and lube lockers
hoping to get my custom knuckles on and gear my axles this winter.
stretch the front a tad
hydro assist
chromos
basically get it ready to handle 35s. it wont be wheeled for a while now that school is back in session.
Old September 7th, 2013, 03:08 AM   #14
OttoMan
OttoMan's Avatar
Looks good, it has come along way.
OttoMan is offline   Reply With Quote
Old September 7th, 2013, 08:09 AM   #15
GREASYHANDS
GREASYHANDS's Avatar
More details on the WJ knuckles and spindles please.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old September 7th, 2013, 09:04 AM   #16
Needafix
Needafix's Avatar
Sweet!
Let me know the next you are going wheelin
Needafix is offline   Reply With Quote
Old September 7th, 2013, 09:54 AM   #17
reptile610
reptile610's Avatar
Send a message via AIM to reptile610 Send a message via MSN to reptile610 Send a message via Yahoo to reptile610
how do you like the super flex kit? I was thinking about picking that up for mine. hows it handle on the road?
reptile610 is offline   Reply With Quote
Old September 7th, 2013, 10:49 AM   #18
jbsjunk
Little Member
jbsjunk's Avatar
+2 Good info to have.
Old September 7th, 2013, 11:14 AM   #19
VAhasnoWAVES
Dirty South
Originally Posted by Needafix View Post
Sweet!
is this justin's father, mike?
love it, its been a very complete kit out of the box. my suggestions (but this also applies to almost any kit)
- add shackle relocation brackets. night and day difference on ride quality.
- SYE makes a ton of difference. dont even try to tell yourself a Tcase drop is enough.
- dont buy shocks for X amount of lift... if you can, install the parts, cycle the suspension, properly bump stop it, and buy shocks to fit your exact needs.
- drop brackets or long arms would deffinantly be a nice upgrade.
other than that... its everything you need. i even took my trackbar and made it double sheer simply by adding the RE double sheer bracket. ruff stuff heims are a direct fit.
Old September 7th, 2013, 11:23 AM   #20
VAhasnoWAVES
Dirty South
the original inspiration and much of the detail comes from this thread:
Dana 34: D44 hubs & brakes on D30 Knuckle - NAXJA Forums -::- North American XJ Association
the idea is to get locking hubs, better brakes, better steering, and more width on the D30 at a fraction of the price of the WJ conversion or a locking hub conversion.
but for a quick overview...
machined the mating surface down to properly center the Ujoint
turned the spindle down to fit the center bore, leaving a lip for the caliper bracket
chop off the WJ brake bracketry
i welded up a couple holes so that i could properly clock the caliper bracket. in reality i only needed to weld up one. you dont need to do this to the spindle.
all together, bolts are just for mock up. going to go with 1/2" grade8.
i dont like the idea of all of the braking force being held in sheer by 3 hub bolts... so weld here
and here
other than the welding and drilling out the steering arms... its pretty much ready to be installed.
Page generated in 0.58824 seconds with 84 queries
