brake issue on grand am - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 6th, 2013, 06:25 PM   #1
BigBrutus
79Ford
BigBrutus's Avatar
Default brake issue on grand am
I have a 2000 Pontiac grand am and I am trying to figure out a problem. Occasionally when I hit the brakes the brake pedal gets soft for a split secon and then it will be firm again. I have no leaks anywhere and I am clueless. Any help would ne awesome.
BigBrutus is offline   Reply With Quote
Old September 6th, 2013, 06:56 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
Master cylinder or vacuum booster issue.
Old September 7th, 2013, 10:43 AM   #3
davidkassie
davidkassie's Avatar
not very common but have been bit by this, a very loose front wheel bearing can cause the rotor to push the caliper back in causing a long travel on the pedal.. and it may not make noise.. might wanna jack up the car and check, just a thought. but is probably master cylinder issue
davidkassie is offline   Reply With Quote
Old September 7th, 2013, 10:48 AM   #4
Toyfish
Toyfish's Avatar
X2
Sent from my DROID X2 using Tapatalk 2
Old September 7th, 2013, 12:20 PM   #5
muddinman56
blood,sweat and beers
muddinman56's Avatar
Break booster
Old September 12th, 2013, 05:35 PM   #6
BigBrutus
79Ford
BigBrutus's Avatar
Thanks for the help. Would a bad master cylinder cause abs light to turn on? I have to test all my abs sensors when I get a chance. Found a site that tells how to teat them.
Old September 12th, 2013, 05:52 PM   #7
in2deep
Hole tester
is the abs unit on the master cyl? if so it could be that the leak internally
Old September 23rd, 2013, 10:15 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yes but a bad wheel bearing would be my bet for the ABS.
Just run up to the local AutoZone or something like that. They will pull the code for you for free.
Old September 23rd, 2013, 10:52 PM   #9
Nuggets
I fix stuff!
Nuggets's Avatar
Looks like the wheel bearing thing might have something to it.
Page generated in 0.28439 seconds with 50 queries
