Welding Cast Iron Advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 3rd, 2013, 08:00 PM   #1
techman
Default Welding Cast Iron Advice
I have the following part that I am trying to repair. I have tacked it together for alignment. I have read that I need to use a high nickel rod and use an arc welder. I plan to notch out the break and weld one side, then then notch out the other side and weld it.
Reasonable plan?
-tim
ID:	110090   Click image for larger version
techman is offline   Reply With Quote
Old September 3rd, 2013, 08:04 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Sounds good you just need to preheat, peen with a punch after every pass and let it cool very slowly. Being that small of a piece I would wait til the wife isn't around and preheat in the oven and put it back in the oven after you are finished and slowly bring the temp back down.
Old September 3rd, 2013, 08:15 PM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
if only we had a tech forum.......
oh we do, moving.
Old September 3rd, 2013, 08:21 PM   #4
chadcooper55
I did a little searching and this is a pretty good write up on Lincoln's site.
http://www.lincolnelectric.com/en-us...on-detail.aspx
Old September 3rd, 2013, 08:24 PM   #5
techman
That's a pretty good article. Lot's of conflicting articles, that one takes both approaches and compares them. Thanks.
Old September 3rd, 2013, 08:28 PM   #6
stuftmunky2k
stuftmunky2k's Avatar
Ni rod is pretty easy to run just dont let the part cool down way to fast. ive also had really good success with tig welding cast with aluminum bronze filler wire. just dont forget grind all the gunk out thats possible and peen it after welding and keep fingers crossed it doesnt crack someplace else. welding cast is a luck of the draw type deal
stuftmunky2k is offline   Reply With Quote
Old September 3rd, 2013, 08:30 PM   #7
chadcooper55
IMO stick to the preheat version, not the keep it cool version.
Old September 3rd, 2013, 08:33 PM   #8
chadcooper55
A2 bronze will work for tig welding cast but you won't have the tensile strength that you would have with arc welding. You can also braze it but once again you don't have the strength. Welding cast is not difficult but you need to spend time prepping everything properly.
Old September 3rd, 2013, 08:35 PM   #9
Lousypirate
Whoop Whoop
Lousypirate's Avatar
you can always braze it too... afaik
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old September 3rd, 2013, 08:37 PM   #10
chadcooper55
See post above you
Old September 3rd, 2013, 08:40 PM   #11
stuftmunky2k
Your exactly right didn't even look at the picture he posted. prep is 3/4 the battle with welding
Old September 3rd, 2013, 08:40 PM   #12
Lousypirate
Whoop Whoop
See post above you
I must not have had the most recently refreshed page. If the brazing isn't as strong, why have I watched my dad do that to cast iron gears numerous times?
plus, the fumes smell delicious!?
Mary Jane (46 CJ2a)
Old September 3rd, 2013, 08:46 PM   #13
chadcooper55
Braze is great because it is very pliable compared to weld. You don't get the parent material to the point where it becomes molten, you only get it hot enough to melt the braze. It is the same with a2 bronze or silicon bronze tig wire. Actual weld melts into the parent material instead of just sticks to it.
Old September 3rd, 2013, 08:51 PM   #14
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Why are we peening it? Please explain.
Old September 3rd, 2013, 08:53 PM   #15
chadcooper55
The metal is brittle and any added tension can cause cracks as it cools. You peen it when it is hot to de-stress the weld so it isn't as prone to cracks.
Old September 3rd, 2013, 09:05 PM   #16
Mr.Green
I can levitate!
Mr.Green's Avatar
oh we do, moving.
This is still in the pub.
Old September 3rd, 2013, 09:28 PM   #17
chadcooper55
Says general tech on my phone.....
Old September 3rd, 2013, 09:48 PM   #18
chadcooper55
Old September 4th, 2013, 06:37 AM   #19
knaffie
knaffie's Avatar
Brazing is the easiest and best way to repair cast iron when high heat during use isn't an issue. Pretty much zero chance of it cracking. No preheat. No postheat. No short welds. No peening. It just works.
The lack of tensile strength is not an issue most of the time. Only when the parent material is very high strength (not all "cast iron" is created equal) and actually sees that type of load in use.
So many people think that brazing is not as strong as steel. One of our many assignments I did in school was to braze steel parts together then put them through a guided bend tests and tensile pull tests. If the brazing and prep were done correctly, the steel fractured and the brazed filler material held. I'm not saying that will be the case with high strength alloys, but with mild steel it is.
Old September 4th, 2013, 06:43 AM   #20
BIGBEN
All out Idiot
BIGBEN's Avatar
^^^this^^^
Plus the braze likes a rough surface, and will bond nicely with cast material. I always prefer to brave cast instead of weld.
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Tags
meballs
Page generated in 0.45278 seconds with 84 queries
