YJ full size axle swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 3rd, 2013, 08:56 PM   #1
sleeperd2
sleeperd2's Avatar
Default YJ full size axle swap
I got a couple questions about swapping out my d30 and d35. Can you run the stock yj springs and just change the perches on the axles? And does any one have pics of there swaps?
sleeperd2 is offline   Reply With Quote
Old September 3rd, 2013, 09:23 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Most probable
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old September 3rd, 2013, 10:50 PM   #3
Wramblerguy
Wramblerguy's Avatar
Yes
With the wagoner axle it is easier to just use stock perches in the front and outboard the springs
3rd generation jeeper
Old September 4th, 2013, 07:52 AM   #4
sleeperd2
sleeperd2's Avatar
Ok so I got a set of axles out of a 88 full size blazer both are 10 bolts with 4:10s. Will those work? I dont do any hard wheeling just some 2 tracker.
Old September 4th, 2013, 08:08 AM   #5
Wramblerguy
Why do an axle swap then?
Old September 4th, 2013, 08:37 AM   #6
sleeperd2
sleeperd2's Avatar
For the width so its not so tipsy. And the ten bolts gotta be stronger than the d30 and d35
Old September 4th, 2013, 08:39 AM   #7
kmanxj5011
kmanxj5011's Avatar
chevy front axle won't bolt in. Differential is on the wrong side.
kmanxj5011 is offline   Reply With Quote
Old September 4th, 2013, 08:43 AM   #8
Lousypirate
Whoop Whoop
Lousypirate's Avatar
If they did have the diff on the correct side, I would recommend limiting straps in case you get some flexy time to keep it from articulating further than your driveshaft.
Lousypirate is online now   Reply With Quote
Old September 4th, 2013, 08:47 AM   #9
sleeperd2
sleeperd2's Avatar
The diff side dont bother me running a built 4.2 with a th400 and np205
Old September 4th, 2013, 08:52 AM   #10
Lousypirate
Whoop Whoop
please include all pertinant information at initial post if at all possible
That does seem like a lot of work for a trail runner...
Old September 4th, 2013, 09:18 AM   #11
The most common breakage in a D30 is the u-joint. However, it's the same size as the 10 bolt, so no improvement there. If you want a wider stance, just go with wheels with less back spacing. I don't think you are gaining much with that swap.
Old September 4th, 2013, 09:38 AM   #12
sleeperd2
sleeperd2's Avatar
Ok well maybe I will just stick to the d30 and d35. Any good ideas on making the steering work on a soa set up with out it hitting the leaf spring?
Old September 4th, 2013, 09:50 AM   #13
Wramblerguy
Wj knuckles
The passenger side knuckle has a high steer arm for the drag link
And I agree that you wouldn't be gaining much with a 10 bolt over a Dana 30
Old September 4th, 2013, 09:56 AM   #14
Lousypirate
Whoop Whoop
Originally Posted by Wramblerguy View Post
Wj knuckles
My only two cents to that is that if you have it on a spindle, you might end up with cheaper replacement parts because of the unit bearings... and locking hubs
Old September 4th, 2013, 10:00 AM   #15
sleeperd2
sleeperd2's Avatar
So do I need both sides of the wj knuckles or just pick up the passenger side?
Old September 4th, 2013, 10:32 AM   #16
kmanxj5011
kmanxj5011's Avatar
I would get rid of that D35, find a 8.8 to put in there.
Old September 4th, 2013, 10:46 AM   #17
kkodet
kkodet's Avatar
I thought the YJ joints were the smaller ones, and they only "upgraded" to the larger joints in 96-01 XJs and 97-06 TJs
Also the most direct "bolt in" full width axles for your rig is a set of axles out of a 78-79 Ford F-250 or 350 (or a fairly rare supercab 150)
This will get you either a 44 or 60 front and either a 9 inch, Dana 60 or 70 rear.
The spring perch width is very similar for the front axle. After that you still have to fab steering, shock mouts, etc. Front driveshaft may or may not work.
IMO this would only be if you are looking to go big and wide. For a YJ, building a 96-99 HP 30 and a Ford 8.8 is a nice combo up to 33-35 inch tires.
Old September 4th, 2013, 10:46 AM   #18
koochman450r
koochman450r's Avatar
I have a 81 j20 front 44 if your interested. 8 lug axle
you won this battle.
Old September 4th, 2013, 11:40 AM   #19
I can't answer that. I just remember that my 90YJ had 760 joints in it. How/why, I can't answer.
Old September 4th, 2013, 11:55 AM   #20
kmanxj5011
kmanxj5011's Avatar
And I had a 2000 XJ with the smaller joints. Weird.
Page generated in 0.27082 seconds with 83 queries
