6.0 PSD oil - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 3rd, 2013, 06:19 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default 6.0 PSD oil
What oil are you guys running in your ford 6.0L's?
I'm not interested in anything amsoil or royal purple. Thanks!
Old September 3rd, 2013, 06:23 PM   #2
Rock solid been advertising Revx from what I here its geared more specifically to the 6.0L
Might be worth looking into.
Old September 3rd, 2013, 06:24 PM   #3
97jeepcherokee
i got the jeep thing
97jeepcherokee's Avatar
i dont personally own one but service a couple fleets of them and we always run motocraft 10w30 diesel oil, helps them start in cold weather
just my .02
97jeepcherokee is offline   Reply With Quote
Old September 3rd, 2013, 06:25 PM   #4
littletrucker
I'd hit that
littletrucker's Avatar
I do not run oil in mine... I figured it would last just as long either way
Old September 3rd, 2013, 06:30 PM   #5
97jeepcherokee
glenn at engineered diesel also sells rev x and its not oil its an oil additive. ive seen it work wonders on older high mileage stuff.
Old September 3rd, 2013, 06:41 PM   #6
Spudy
Redneck Excavator
Spudy's Avatar
rotella 15w40
Spudy is offline   Reply With Quote
Old September 3rd, 2013, 07:06 PM   #7
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Thanks spud
Old September 3rd, 2013, 08:20 PM   #8
revdog
Ran rotella 15w40 since new. No oil related issues in a 120000 miles. Run rotella 5w40 in my new 6.7 with no worries.
Sent from my DROID RAZR using Tapatalk 2
revdog is offline   Reply With Quote
Old September 3rd, 2013, 08:27 PM   #9
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Originally Posted by Spudy View Post
rotella 15w40
What I ran in my last company ride with a 6.0.
Old September 3rd, 2013, 08:32 PM   #10
XLJetsFan52
Just a good ole' boy
XLJetsFan52's Avatar
I may not have a 6.0, but when i used to work at Valvoline, i put 5w40 Valvoline Premium Blue Extreme in a lot of them. Its what i run in my diesel.
XLJetsFan52 is offline   Reply With Quote
Old September 3rd, 2013, 08:33 PM   #11
hamsmotorsports
hamsmotorsports's Avatar
Run what ever diesel oil you want just keep if fresh and use the revx additive.
hamsmotorsports is offline   Reply With Quote
Old September 3rd, 2013, 08:38 PM   #12
370
370's Avatar
I read up on this same topic a lot on the diesel forums. seems that the popular oil is delo 5w40 syn. I put it in mine with rev x and its been great.. i switched from schaffers which was terrible on cold starts.. before that was rotella 15w40. switching from the rotella to the schaffers I noticed a difference immediately. stay away from the schaffers. the big topic of discussion on the diesel forums what phosphorus in the oil.. some connection between phosphorus content and resistance to inje for spool valve sticktion.
370 is offline   Reply With Quote
Old September 3rd, 2013, 10:32 PM   #13
Kane
Got Jeep?
Kane's Avatar
I used Rotella 15w40 with no problems when I had my 6.0 PSD.
Kane is offline   Reply With Quote
Old June 11th, 2014, 08:11 PM   #14
I think I may use AR9100 in my oil changes over rev-x.
I was researching the rev-x, and came across this thread, very long read over a couple years time with posts.
Rev-X exposed - TheDieselGarage.com
Another informative link from that thread.
http://www.dieselpowermag.com/newpro...e_diesel_tech/
Old June 11th, 2014, 08:23 PM   #15
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Update: had some injector stiction issues a while back(right when diesel power did the archoil feature) bought it and ran it as and almost instantly fixed the issue just as they described in the article.
Old June 11th, 2014, 09:49 PM   #16
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Thanks John. Ar9100 is a new thing for me. Only on really cold mornings last winter I had the cold start issue... I will be putting it in.
Cheap Thrills Off Road
Page generated in 0.35728 seconds with 72 queries
