Smaller oil filter? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 2nd, 2013, 03:11 PM   #1
Default Smaller oil filter?
I used to have the part number but lost it and can't find where I found it.
I run the napa #31515 on my Windsor. I know their is another filter that fits that is smaller in circumference. I need just a little smaller filter to clear things better.
The dimensions of the filter are
Height (Inches) : 5.178"
Thread Size (Inches) : 3/4-16
Filter O.D. (Inches) : 3.66"
Filter O.D. (mm) : 93 mm
Gasket I.D. (Inches) : 2.462"
Gasket I.D. (mm) : 62 mm
Gasket O.D. (Inches) : 2.834"
Gasket O.D. (mm) : 72 mm
Height (mm) : 131 mm
Old September 6th, 2013, 03:46 PM   #2
sandguy356
bronco built for fun
sandguy356's Avatar
a Wix 51516 is just a little shorter and less in diameter.
Height 4.828
thread 3/4-16
OD 2.921
Gasket ID 2.430
Gasket OD 2.734
sandguy356 is offline   Reply With Quote
Old September 6th, 2013, 05:51 PM   #3
s.hembree
s.hembree's Avatar
The 51085 is identical but a little over 1.25" shorter if that helps...
Old September 6th, 2013, 06:05 PM   #4
Its more circumference then height that is an issue.
What I run kinda clears, but smaller would be more piece of mind.
Page generated in 0.21833 seconds with 35 queries
