My new little piece of history - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 1st, 2013, 10:39 AM   #1
muddinman56
blood,sweat and beers
muddinman56's Avatar
Default My new little piece of history
So I recived a call the other day from a family member saying they are getting rid of this old tractor and asked if I wanted it and if not it would probably be scraped or tried to be sold.
So of corse I wanted it. It was my dads uncles old tractor and he has had a ruff time these last 5 years with heart problems and what not.
So more about the tractor what I know about it right now is its a ford 9n they made these from 1939-1942 and this one runs drives operates great. But doesn't look the best yet.
I got the tractor for free and came with a furrier,disks and back blade.
I think these tractors look sweet when there cleaned up painted and looking nice.
The tractor needs a tube for the rear tire and one front tire that's why it sits funny in the pic
Old September 1st, 2013, 11:56 AM   #2
howell_jeep
Last Free Man
howell_jeep's Avatar
sweet. Are you planning or restoring it or using it as is?
howell_jeep is offline   Reply With Quote
Old September 1st, 2013, 12:13 PM   #3
muddinman56
We're deffently going to use it and do a mild resto just get every thing working great and clean it up get all the parts it needs like new hood lights stuff like that and paint it
It just weird to me that the tractor was made at the start of ww2 and it all still works as it should they don't make things like that any more
Old September 1st, 2013, 12:30 PM   #4
oilburner350
oilburner350's Avatar
Last I knew Van Pamels in Armada has repop parts for it, as well as Steiner's and Owosso Tractor parts.
Pretty simple tractor to work on. The lack of live power and live hydraulics can get annoying, but it's nothing that can't be worked around. Just takes more time.
Paint it up, use it, and take it to shows.
oilburner350 is offline   Reply With Quote
Old September 1st, 2013, 08:43 PM   #5
WSU JK
WSU JK's Avatar
Location: Lowering the Per-Capita Income of Bloomfield Hills since 2009!
Very cool.
My dad had one from the next generation and used it regularly from when he got in (late 1960s) until he sold it just a couple of years ago. Like oilburner said, those old Ford tractors are lacking in many options that we take for granted now but are amazingly simple to work on.
WSU JK is offline   Reply With Quote
Old September 2nd, 2013, 04:09 AM   #6
I suck cocks. Lots of them.
locally famous
Seen one of those yesterday that was painted a darker shade of gray, with blacked out rims. Looked real nice like that.
Old September 2nd, 2013, 06:45 AM   #7
oilburner350
Just as a side note the engine in the 9N-2N-8N was based off of the flat head V8 with some of the internals beefed up. If I remember correctly they also used a one ton truck clutch. Old Henry used what he had on the shelf to build his tractors.
Old September 2nd, 2013, 06:52 AM   #8
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
The 9n has a rear pto
Old September 2nd, 2013, 07:04 AM   #9
oilburner350
It sure does have a PTO, but it is not live. You had to go to the later tractors to get the live or independent PTO. Live is achieved with a two stage clutch, independent has a separate clutch pack. On the N series once the clutch is disconnected the PTO no longer has power to it.
If you want a thrill put a brush hog or finish mower on a 9N-2N-8N with no over running clutch and try to stop in a hurry.
Some of the N tractors also have a Sherman axillary transmission. One thing to keep in mind is there is only one power input to the transmission. If the Sherman speed or slows the ground speed it also changes the PTO speed.
Old September 2nd, 2013, 07:21 AM   #10
Christmas Cookie
I thought you were suggesting it had no pto, ill shut up now
Old September 2nd, 2013, 07:38 AM   #11
booblinker
Sore and Tired 24/7
booblinker's Avatar
Wasn't a flathead v8 swap pretty easy?
Old September 2nd, 2013, 07:40 AM   #12
oilburner350
I've worked on tractors for 20+ years. Everything from a 1926 McCormick Deering 10-20 to new stuff.
With the 3 point the N series was pretty high tech for its time. My Great Grandpa tried one out in 1940 along with the A Farmall, B Allis-Chalmers, Oliver 60, and H John Deere. They settled on the H, but were too cheap to pay $25 for the electric start. The 14 hp Deere replaced 2 teams of horses.
Old September 2nd, 2013, 07:45 AM   #13
oilburner350
Yes and no. Funk made a 6cyl and 8 cyl conversion. The main problem with the V-8 was the tractor was a structural block, the V-8 was not. It took a lot of reinforcement so that the block wouldn't crack. I think the radius arms and some other stuff had to be changed as well. The 6cyl need a new hood and radiator. One of my friends had both conversions.
Back in the day my great uncle used to order a rebuild kit for I think it was the 239 flat head and an extra pan gasket. It was a cheap way to get two rebuild kits for the N series.
Old September 2nd, 2013, 08:20 AM   #14
muddinman56
You sure know your stuff about tractors lol
I power washed it and it looks better
And what a bitch it is to break the rear tire beads to put a tube it
Old September 2nd, 2013, 08:51 AM   #15
muddinman56
What I need is the hydraulic fluid can I go to tractor supply and get some I understand it needs or calls for mineral sprits sae 80 but can I use other stuff?
Old September 2nd, 2013, 09:38 AM   #16
oilburner350
If the tire has been on there a while the tire rusts to the rim, plus old hard tires are just a pain to break down. I have use a board/another tractor, back blade with 3pt hitch that has down pressure and a dozer to break them down. Do you have a tire hammer?
Old September 2nd, 2013, 09:38 AM   #17
oilburner350
Here is an article on hydraulic fluid for the N series- http://www.yesterdaystractors.com/ar.../artint251.htm
The original mineral oil is very slow in cold weather. If it were my tractor and the hydraulic system is in good shape I would drain it and refill with a Hydraulic/Transmission oil meeting the Ford M2C134D spec. It will work better in the winter if you plan on using it for snow removal.
Old September 2nd, 2013, 11:09 AM   #18
muddinman56
The hydraulic system is in great shape we just don't know what other fluid we can run in it that won't hurt the machine or the seals.
And ya I have a slide hammer and crow bars it worked just it was a bitch lol
Old September 2nd, 2013, 11:29 AM   #19
muddinman56
U don't happen to have any ford 9n stuff laying around do ya?
Old September 2nd, 2013, 12:11 PM   #20
skife
skife's Avatar
we sell "tractor fluid" at autozone. i know its mineral oil, i don't know what weight it is.
Page generated in 0.61434 seconds with 82 queries
