TJ heavy duty steering kit - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 31st, 2013, 11:21 AM   #1
2fst4you
2fst4you's Avatar
Default TJ heavy duty steering kit
Bent my rugged ridge crossover steering tie rod pretty bad so its time for a new one what you all got?
Old August 31st, 2013, 04:54 PM   #2
DuffMan
Your Message Here
DuffMan's Avatar
NIB Rough Country HD TJ tie rod. Going in a different direction.
Pick it up in 48138 for $60
Old September 9th, 2013, 03:14 PM   #3
2fst4you
2fst4you's Avatar
Ttt
Old September 30th, 2013, 12:09 AM   #4
2fst4you
2fst4you's Avatar
Bump
Old October 9th, 2013, 01:09 PM   #5
2fst4you
2fst4you's Avatar
Old November 16th, 2013, 07:31 PM   #6
2fst4you
2fst4you's Avatar
Bump
Old November 16th, 2013, 07:39 PM   #7
firehawk
Live Action!
firehawk's Avatar
One ton Steering from Whiterhinos rig - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2013, 04:05 PM   #8
2fst4you
2fst4you's Avatar
Bump needs to be for d30 knuckles
Old November 29th, 2013, 05:51 PM   #9
Scottkillingbeck
R & V Ranger
Scottkillingbeck's Avatar
Jeep TJ Over the Knuckle Steering by JCR, brand new, $200 - Great Lakes 4x4. The largest offroad forum in the Midwest
Can be delivered as close as fenton for pickup given a few days.
Scottkillingbeck is offline   Reply With Quote
Old November 29th, 2013, 06:54 PM   #10
firehawk
Live Action!
firehawk's Avatar
You can ream the holes out for bigger tie rods.
Old November 29th, 2013, 10:03 PM   #11
2fst4you
2fst4you's Avatar
I'm am interested if reaming my knuckles aren't expensive
Old November 29th, 2013, 11:47 PM   #12
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
cam,
youll have to ream your knuckles regardless if you go UTK or OTK. your better off drilling out the knuckles and adding an insert with the correct taper. the inserts and drill bit are far cheaper than a the cost of a reamer... and you wont have two opposing tapers in the same hole.
http://www.ruffstuffspecialties.com/.../INSSTEER.html
FWIW, you dont really want the one ton setup. google "tie rod roll." if you want some other ideas, PM me.
VAhasnoWAVES is offline   Reply With Quote
Old November 30th, 2013, 02:07 PM   #13
2fst4you
2fst4you's Avatar
I currently have this but its bent so I'm looking for a replacement
http://www.extremeterrain.com/rugged...j-1805082.html
Old November 30th, 2013, 02:35 PM   #14
firehawk
Live Action!
firehawk's Avatar
Bend it back!
Old November 30th, 2013, 03:06 PM   #15
2fst4you
2fst4you's Avatar
The tie rods are shot too not worth it
Old November 30th, 2013, 04:19 PM   #16
Tab
Tab's Avatar
If you gotta get all new anyway, I ran a v8 grand Cherokee setup for four years with no bending. But you probably wheel harder than I do. It's quite a bit bigger and you can get it from any auto parts place for around $120 for the complete set up with the heavier duty ends.
Old November 30th, 2013, 07:59 PM   #17
2fst4you
2fst4you's Avatar
Is that for the drag link and tie rod? That's a pretty good deal. Ran that for 4 years on your current jeep?
Old November 30th, 2013, 08:21 PM   #18
Tab
Tab's Avatar
Yeah if I remember right both pieces was right around $60 or something. That was back when my jeep was on 33's. I run full hydro now.
Old November 30th, 2013, 09:00 PM   #19
2fst4you
2fst4you's Avatar
Did you wheel it pretty hard then? I rock crawl a lot run all the black diamond trails doesn't mean I make it through them all without winching though haha
Old November 30th, 2013, 09:11 PM   #20
Tab
Tab's Avatar
Yes, I wheeled it hard. pretty much the same as I do now only on 33's. It was never an issue but that's not to say you couldn't bend it if you just continued to drive it into immovable oblects.
Page generated in 2.46303 seconds with 84 queries
