TWIN STICKS for dana 300/1ton axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2013, 01:12 AM   #1
89cjwftw
jeeprbrown
89cjwftw's Avatar
Default TWIN STICKS for dana 300/1ton axles
looking for the shifter sticks for a dana 300.
Also looking for a set of complete axles. front passenger side drop hp dana 60 and leaning towards a 14 bolt rear, if you have other one ton axles let me know and i will consider but would like to buy a set together. pm me if ya got a set
thanks
89cjwftw is offline   Reply With Quote
Old August 30th, 2013, 11:23 AM   #2
bigyj
bigyj's Avatar
Driver or passenger drop front?
bigyj is offline   Reply With Quote
Old August 30th, 2013, 11:38 AM   #3
itselliott
itselliott's Avatar
I have factory long and short shifters. Very simple and CLEAN twinstick set up. Easy to do.
pm if interested
Just cut the tubes from the D60 yesterday..........you can have the center if you want it.
Old August 31st, 2013, 12:06 AM   #4
89cjwftw
jeeprbrown
89cjwftw's Avatar
Passenger side drop and holland is a bit far for just the sticks lmk if your ever close to lake orion, auburn hills, or pontiac tho
Old August 31st, 2013, 03:33 PM   #5
lt1yj
Kill two birds with one stone.
I have an '86-91 HP60 and a '73 14 bolt. The 60 is complete as it came from the truck.
The 14 bolt does not have the carrier, pinion or calipers. It has been converted to disks. The brackets are kinda hokey but they work.
$900
lt1yj is offline   Reply With Quote
Old August 31st, 2013, 08:27 PM   #6
BigWheelBob
The 4 Wheel Drive Shop
BigWheelBob's Avatar
Call me. I have some passenger drop 4.56 fronts, with 14 bolt rears, and 456 w detroits. Also im sure i have the twin stick new in stock. Bob, 231-766-1567
BigWheelBob is offline   Reply With Quote
Old August 31st, 2013, 08:33 PM   #7
89cjwftw
jeeprbrown
89cjwftw's Avatar
Will give ya a shout tomorrow thanks
Old August 31st, 2013, 09:38 PM   #8
89cjwftw
jeeprbrown
89cjwftw's Avatar
just how much stronger is the 14 bolt over a rear 60 or the sterling 10.25 any clue guys?
i kept reading that the 14 bolt is a like an anchor but if im planning to run 40s or bigger that shouldnt be to much of an issue, am i correct? kinda starting to lean towards the 14 bolt just want more input. thanks
Old September 4th, 2013, 05:34 AM   #9
89cjwftw
jeeprbrown
89cjwftw's Avatar
Old September 4th, 2013, 06:00 AM   #10
bigbchevy
missmrgreenagain
bigbchevy's Avatar
The 14 bolt is bad ass just shave off the bottom of the housing ! The 60 shafts are weak and the sterling doNt have a lot of options when it comes to locker gear combos
H.o.r.e
Old September 5th, 2013, 06:07 AM   #11
itselliott
itselliott's Avatar
Just an FYI
http://www.greatlakes4x4.com/album.p...pictureid=9672
Factory sticks bolt directly to the T/C NO linkage involved.......Just a 1/2" shoulder bolt and the lower ball ( of the stick) slips into the little adapter plate on the shift rod.
Old September 5th, 2013, 05:20 PM   #12
89cjwftw
jeeprbrown
89cjwftw's Avatar
thanks for the info guys
Old September 8th, 2013, 12:22 PM   #13
89cjwftw
jeeprbrown
89cjwftw's Avatar
keeping my eye out for front 60 and 14 bolt rear 4.56 gears or close to lt as possible
Old September 8th, 2013, 12:23 PM   #14
89cjwftw
jeeprbrown
89cjwftw's Avatar
bigwheelbob, you ever head down towards detroit at all?
Old September 8th, 2013, 01:04 PM   #15
BigWheelBob
nope
Tags
meballs
Page generated in 0.28856 seconds with 68 queries
