What motor swap for a Blazer? SBC? Big Block? LSx? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 29th, 2013, 11:48 AM   #1
Default What motor swap for a Blazer? SBC? Big Block? LSx?
We are thinking about a full size blazer, to fit the family and still have a convertable. Something on 33s or 35s, mainly street duty, and maybe sand dunes. Not a general purpose wheeler.
Would want the engine to really get the blazer moving. I am thinking 500 crank HP..
I've never owned a blazer before so have no ideas of what the challenges are with motor swaps, but I'm assuming its a lot easier than swapping into a Jeep CJ!
Thinking there's 3 options:
1) Build a small block, which is obviously a bolt-in.
2) Build and swap in a big block
3) Build up an LSx motor
Your thoughts?
Old August 29th, 2013, 11:50 AM   #2
ricthewrench
i make everything
big block. torque is what gets things moving, bb has it to give. jmo
ricthewrench is offline   Reply With Quote
Old August 29th, 2013, 12:05 PM   #3
BOGDOG
BOGDOG's Avatar
I'll second the big block, should pretty much bolt in as well.
Old August 29th, 2013, 12:11 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
LSX. 500HP should be easy and run nice, not lumpy.
Old August 29th, 2013, 01:47 PM   #5
Iggy
Iggy's Avatar
Torque and HP are two different things. 500 HP from a big block should deliver close to 600 lb/ft of torque. 500 HP from a small block will produce only around 400 lb/ft torque but at a much higher rpm than the big block. An LS engine will produce slightly more torque for a 500 HP engine than the small block, but at a more usable (around 4000 rpm) engine range than the gen 1 small block.
If you are towing or off-roading, the big block is best. If general driving on street empty, the LS would be better.
Iggy is offline   Reply With Quote
Old August 29th, 2013, 01:49 PM   #6
montecarlo33
The Violator
montecarlo33's Avatar
x2 Normally I would vote big block, but a LS swap makes it also a good driver with decent mpg's. With proper gearing it should be all you need.
Old August 29th, 2013, 01:51 PM   #7
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
I like the big block idea, with maybe a fuel injection adder.
Old August 29th, 2013, 01:56 PM   #8
Lousypirate
Whoop Whoop
Lousypirate's Avatar
lsx, those are aluminum too right? help keep it lighter overall. fuel injection for street duty.
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old August 29th, 2013, 02:00 PM   #9
montecarlo33
The Violator
"lsx" basically means any LS series engine. They made them both iron block with aluminum heads(older) and a aluminum block with aluminum heads(newer more expensive, but a tad more power and less weight).
Old August 29th, 2013, 02:20 PM   #10
Lousypirate
Whoop Whoop
Isn't there an ls x crate engine?
Mary Jane (46 CJ2a)
Old August 29th, 2013, 02:23 PM   #11
If only there was some sort of ratio to tie the two together
I'd just like to see the OP finish a project
Old August 29th, 2013, 02:26 PM   #12
There are a few specifically called LSX, the LSX376 abd LSX454, both with the iron LSX block.
I do happen to have an all aluminum LS2 and built 700R4 just sitting on the floor. 400hp/400 ft lbs stock..
Old August 29th, 2013, 02:27 PM   #13
ljense8
Web Wheeler
ljense8's Avatar
If it's a DD I would go LSx. With that much power you will want to box the frame or it will cause some serious problems. Check out DIY4x4.com for solid mounts and he also has a precut frame boxing kit for K5 Blazers. CK5.com has a lot of knowledgeable people regarding all aspects of K5 Blazers, including various engine swaps. Another option would be an 8.1, giving you good low down torque and the driveability of a newer engine.
ljense8 is offline   Reply With Quote
Old August 29th, 2013, 02:34 PM   #14
montecarlo33
The Violator
end thread.
Old August 29th, 2013, 02:42 PM   #15
Lousypirate
Whoop Whoop
end thread.
x2
Mary Jane (46 CJ2a)
Old August 29th, 2013, 03:03 PM   #16
just a cruiser. no wheeling except maybe the dunes once a year. Not a dd either.
Old August 29th, 2013, 03:19 PM   #17
kickstand
circling the drain
kickstand's Avatar
I was just going to say, theoretical engine/project build number skooterbuilt-1=haggar
kickstand is online now   Reply With Quote
Old August 29th, 2013, 03:22 PM   #18
ljense8
Web Wheeler
ljense8's Avatar
If it's not a DD then a 454 with a lumpy cam would give it a sweet sound and great torque. Either way, I would recommend boxing the frame so it doesn't twist with that much power.
Old August 29th, 2013, 05:08 PM   #19
The problem, is all the projects I post on this site don't make it, and all the vehicles that I have/build that I don't post here (In the last few years, there's the TJ I rebuilt, the XJ I rebuilt, and my current CJ7), then those I get done, and enjoy them a bunch.
This is our current CJ7, but it doesn't fit all 5 of us, so thinking of something bigger... I really don't wheel much anymore, but we like the dunes. Want some old school iron in a convertible that will fit 5 people.
Old August 29th, 2013, 05:22 PM   #20
skife
skife's Avatar
had a 90 k5 with a LT1 in it, ~280hp ish at the crank (factory rated) It wasn't a slouch...
500hp is going to be killer. I'd suggest 5.3 with a cam and spray.
Page generated in 0.39000 seconds with 84 queries
