4x4 not working? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2013, 04:13 AM   #1
Ajhawk
Ajhawk's Avatar
Default 4x4 not working?
in my 96, my 4x4 will shift into 4wd but the front wont spin, i had my dad switch it while i was under it, and its engaging, so?? i was told a few things, like possible vacuum leak or that the actuator? that engages it fully is bad, any ideas?
Ajhawk is offline   Reply With Quote
Old August 28th, 2013, 04:57 AM   #2
boggin-machine
boggin-machine's Avatar
I had an axle shaft go bad in my cummins. Same set up. There's a bushing in there that could be bad and won't alot the sector shaft engage into shaft to fully lock it in. Dodge is also known for the actuator to go bad. Of that's the case pull it off the axle housing and see if its shifting side to side
Old September 19th, 2013, 10:55 PM   #3
88yjproject
The actuator is probably seized. It is pricey!
88yjproject is offline   Reply With Quote
Old December 6th, 2013, 06:08 AM   #4
Ajhawk
Ajhawk's Avatar
little late, but with winter comming up, im going to pull the actuator and see if thats the problem.
Old December 6th, 2013, 01:32 PM   #5
kickstand
circling the drain
kickstand's Avatar
If it is the same design as the YJ's were you can simply slide the actuator over by hand, my housing had a threaded hole with a bolt in it in just the right spot. I removed the bolt and installed a longer one to keep the actuator fork in place to hold the collar in place correctly. Disconnected the vacuum lines and never looked back. My front axle now acted like that of a TJ or other with non disconnect. May be worth checking into.
Old December 6th, 2013, 01:36 PM   #6
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Look at 4x4 POSI LOCKS... I have it on my ram... love it...
ReiKo is offline   Reply With Quote
Page generated in 0.18226 seconds with 41 queries
