Tire size VS Tire Weight - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2013, 11:53 AM   #1
curbdog17
Mini Van
curbdog17's Avatar
Default Tire size VS Tire Weight
A.
I am running 36" Iroks on weld on BeadLocks They weigh in at 114 Lbs. (had them on the scale today).
B.
I am looking at running 39.5" Iroks on non BeadLock aluminum wheels. Tire weight 76lbs wheel weight 15-20 lbs estimated weight 91-96 lbs.
Which one would be harder on the axles? A or B ?
Old August 26th, 2013, 12:08 PM   #2
B.
Old August 26th, 2013, 12:10 PM   #3
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Shafts, B.
Axle housing, A.
curbdog multiplier. both are bad choices.
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old August 26th, 2013, 12:14 PM   #4
curbdog17
Mini Van
curbdog17's Avatar
Originally Posted by Lousypirate View Post
Shafts, B.
Axle housing, A.
I have been running the 36's for a few years and have only had 1 axle shaft snap.
Old August 26th, 2013, 12:14 PM   #5
Lousypirate
Whoop Whoop
You aren't wheeling hard enough.
Old August 26th, 2013, 12:19 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
beer its always beer
H.o.r.e
Old August 26th, 2013, 12:20 PM   #7
curbdog17
Mini Van
curbdog17's Avatar
Thanks for the advise, I think im might be going with the 39.5's then.
Old August 26th, 2013, 12:48 PM   #8
Lousypirate
Whoop Whoop
It will look schmexier
Old August 26th, 2013, 02:07 PM   #9
The unsprung weight of the heavier combo is meaningless and you are only talking about 100 pounds total. If anything, it adds to lowering your COG. You can do your own inertia calcs.
The larger lever arm (tire radius) is harder on all of your driveline and will effect your power for acceleration and power.
Depending on backspacing, whichever is further out will effect your wheel bearings and knuckles.
The taller tires will raise your COg but look much more cool.
Old August 26th, 2013, 04:15 PM   #10
curbdog17
Mini Van
curbdog17's Avatar
All of that makes perfect sense to me. I was having trouble getting high centered on a lot of Rox this past weekend. I'm thinking a larger tire might help me out.
Old August 26th, 2013, 04:54 PM   #11
curbdog17
Mini Van
curbdog17's Avatar
the difference in the actual tire height is only 2.7", so the lever applying leverage would only be 1.35" longer. its hard for me to think that it would be applying that much more leverage on to my axle shaft.
Old August 26th, 2013, 05:25 PM   #12
Lousypirate
Whoop Whoop
Are you on stock shafts?
Old August 26th, 2013, 05:54 PM   #13
but eventually, one more straw breaks the camel's back.
Its going to be something like 10% or so more leverage, if you were on something like a draw strip.
You can't really back it up with real world data, but I suspect that the larger, longer footprint offroad increase the available traction above what the 36 offers, so you have more traction, then that traction acts 10% harder, it all adds up.
Old August 26th, 2013, 06:04 PM   #14
ljense8
Web Wheeler
ljense8's Avatar
The lighter weight will help offset the extra leverage slightly, but the taller tires will still be harder on your drivetrain and steering.
ljense8 is offline   Reply With Quote
Old August 26th, 2013, 06:11 PM   #15
curbdog17
Mini Van
curbdog17's Avatar
Dana 44 With Stock Shafts.
So I Sounds Like I May Be Putting More Stress On My Axle Soon.
Old August 26th, 2013, 06:12 PM   #16
What size rim are the 39.5?
Old August 26th, 2013, 06:15 PM   #17
curbdog17
Mini Van
curbdog17's Avatar
Old August 26th, 2013, 06:35 PM   #18
Lousypirate
Whoop Whoop
I'm still behind the larger tires. Just take into consideration the eventuality that you might break more axleshafts.
If you're like me, you break them once, and then never want to have to fix it again... I went tons. You might still want to consider budgeting for chromo as an eventuality when it does happen.
Old August 26th, 2013, 06:43 PM   #19
No it won't. The lighter weight would only make a difference when inertia (wheel spin) comes in to play. I've seen plenty of axle shafts snap at very low rpm.
Stock D44 shafts are very vulnerable with a 39" tire. I managed to break them quite easily with 35's.
Old August 26th, 2013, 06:55 PM   #20
chevotass
chevotass's Avatar
Keep the 36s. Keep the parks fun and challenging
Page generated in 0.35644 seconds with 83 queries
