Manual T-Case for AOD Trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2013, 08:16 AM   #1
chasetheface123
chasetheface123's Avatar
Default Manual T-Case for AOD Trans
Picked up a 5.0/AOD last week and it came with an electric shift tcase. What are my options for manual shift behind the AOD? It is out of a 93 f-150.
Thanks!
chasetheface123 is offline   Reply With Quote
Old August 26th, 2013, 08:22 AM   #2
trailrail302
Im going FAST!!!
trailrail302's Avatar
Thanks!
Ford kept the same bolt pattern for alot of tcases. you can do a 205 with some fab work to the extension housing or you can put a NP 208 or the BW 1345/1356 (I think thats the correct #) are direct bolt ins.
I have a (2) 208 man shift one has slip yoke the other is a fixed yoke, I will sell either one $125 each
pm me if your interested.
trailrail302 is offline   Reply With Quote
Old August 26th, 2013, 10:03 AM   #3
chasetheface123
Sweet! I've got a 1354 here and didnt even think about it.
Old August 27th, 2013, 06:02 AM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
The BW 1354 is from a ranger/explorer. I do not think it will fit.
Trailrail mentioned a 1345, not 1354.
Old August 27th, 2013, 08:17 AM   #5
chasetheface123
Whoops, misread that. Just realized i've got a 1356 sitting here.. Looks like I'm using that!
Old August 27th, 2013, 08:18 AM   #6
bw4406 is a good option as well.
Old September 15th, 2013, 07:19 PM   #7
Bjones
Bjones's Avatar
all of the full size t cases are the same bolt pattern. IMO the NP205 is the best option, but if you already have a 1356 there's no reason not to use it
Bjones is offline   Reply With Quote
Page generated in 0.20815 seconds with 44 queries
