Track bar advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2013, 10:12 PM   #1
skier206
skier206's Avatar
Default Track bar advice
I have a 2000 TJ with a BDS 6" lift and 35" tires the lift has been on for 13 months and the front track bar bushings have worn out and BDS won't warranty them also the axle bracket has now gotten oblong. So the question I'm asking is I want to change this out and don't want to do it again so what is the best way to go? Buy new bushings, new track bar from a different company if so which one? Thanks in advance
skier206 is offline   Reply With Quote
Old August 26th, 2013, 05:54 AM   #2
pics of your front geometry?
Old August 26th, 2013, 07:36 AM   #3
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Like white rhino said, what does the track bar look like? Is it the style that is bushings on both ends or a bushing on the axle end and a tie rod style end or rod end on the frame side?
For the oval'd hole, probably the best fix would be to weld in a stepped weld washer that would repair and strengthen the bolt hole. With the hole oval'd out, it will constantly a battle to keep the bolt tight, and if the bolt gets loose you get the death wobble causing more damage.
Any idea if the hole was oval'd out before the BDS kit was installed or if it's something that's happened recently?
Weld washer:
http://www.ruffstuffspecialties.com/...Category_Code=
Old August 26th, 2013, 02:29 PM   #4
skier206
skier206's Avatar
The track bar has a rubber bushing on the axle end and a heim joint on the frame end. The axle mount was brand new when I installed the lift
Old August 26th, 2013, 03:19 PM   #5
skier206
skier206's Avatar
I'm working on pictures but the track bar is in line with the drag link both when sitting on the ground or when it is suspended in on the lift
Old August 26th, 2013, 03:42 PM   #6
DirtyMittenMudder
DirtyMittenMudder's Avatar
I put a jks on my tj a few months ago and im happy so far. As said above I would weld a washer to fix the axle mount or you'll continue to go threw bushings.
DirtyMittenMudder is offline   Reply With Quote
Old August 27th, 2013, 07:25 AM   #7
idiot magnet
idiot magnet's Avatar
Check out the metalcloak adjustable track bars. Solid chromoly, won't hit the diff and $160-170.
idiot magnet is offline   Reply With Quote
Old August 27th, 2013, 08:11 AM   #8
jbsjunk
Little Member
jbsjunk's Avatar
A BDS track bar for this lift uses the steering stab diff mount for it's diff location and usually a rod end on the frame side. It really fixes the steering and any death wobble issues. It's not a rubber bushing, but a hard plastic type of 2 piece bushing with a sleeve on the diff side. My shop is a BDS dealer and I've done many of these. They usually warranty bad bushings.
Old August 27th, 2013, 08:31 AM   #9
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I really like the iron rock off-road track bar, double shear. Put it on a 3" lift
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old August 27th, 2013, 09:45 AM   #10
redmud
10 0011 10101
redmud's Avatar
Originally Posted by jbsjunk View Post
A BDS track bar for this lift uses the steering stab diff mount for it's diff location and usually a rod end on the frame side. They usually warranty bad bushings.
This. Post up a couple pictures of what's going on, and we will see what we can do.*
*I am not posting this in any official capacity, but there are not many cases we would not warranty a bushing in after only a year. They are wear items, but a year shouldn't kill them, even if you drive like I do!
BDS Suspension
How can you land a space ship on the moon? How can a snake eat an aligator? how does the internet work? some questions are not meant to be answered by man alone.
redmud is offline   Reply With Quote
Old August 27th, 2013, 12:53 PM   #11
skier206
skier206's Avatar
Here are the pictures.
Page generated in 0.39974 seconds with 57 queries
