Axle help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2006, 08:45 PM   #1
SANDMAN
Shhhhhh
SANDMAN's Avatar
Default Axle help
Ive got a popping sound in the front end but only when then hubs are locked in.. I have the front lincoln locked and dont always run both hubs locked but know matter what side is locked in at the hubs its popping....Any Ideas????
Thanks
SANDMAN is offline   Reply With Quote
Old November 8th, 2006, 08:41 PM   #2
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
we are talking about a toyota axle right?
could be a slopply Birf or worse a broken birf. then again could be your r&p could be toast. only one way to find out, pull off the knuckle on the side that is making the noise and take a peek.
nmeinc is offline   Reply With Quote
Old November 9th, 2006, 08:58 PM   #3
ELFJ40
I like sparklers
ELFJ40's Avatar
Agreed on the birf, Size of tires 35+? Do any backing up while turning the wheels?
ELFJ40 is offline   Reply With Quote
Old November 10th, 2006, 05:23 PM   #4
SANDMAN
Shhhhhh
SANDMAN's Avatar
Yep its a Toyota axle running 35's it only makes the noise while trying to turn
Old November 10th, 2006, 05:31 PM   #5
As mentioned, could be various things.
Might be a bent housing. I think my front *might* be warped a bit.
I get a metal on metal screeeeeeeee sound every now and then from my right knuckle when I turn. But the 30 spline longs are a lot bigger than stock birfs so don't have much clearance, so are more succeptable to rubbing the housing.
Page generated in 0.19218 seconds with 38 queries
