ford trans question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2013, 08:43 PM   #1
chevy454
Landscaper from hell
Default ford trans question
Ok I have a 96 ford f150 4x4 with what I think is an 4r70w. People are telling me its not a 4r70w that its an aode because ford didn't use it in the trucks until 97. The door has a U code for the trans. Anyone able to help me so I know what trans to buy?
chevy454 is offline   Reply With Quote
Old August 21st, 2013, 09:54 PM   #2
TJ/WILLYS
TJ/WILLYS's Avatar
I have a 95 f-150 351/E40D trans. How many bolts in trans pan?
TJ/WILLYS is offline   Reply With Quote
Old August 21st, 2013, 10:34 PM   #3
chevy454
It has a 14 bolt pan
Old August 22nd, 2013, 12:28 PM   #4
blackbronco92
300 Inline 6
blackbronco92's Avatar
A 14 bolt pan would indicate an old style AOD, which has not been in an F-150 since 1993.
The E4OD will have a 20 bolt pan.
The AODE/4R70W will have 16 bolts.
The AODE and 4R70W are identical, except that the 4R70W has a bolt pattern to fit the newet 4.6L and 5.4L modular V8's not found in trucks until '97.
Your truck will have an AODE or an E4OD, with the latter being much more common.
blackbronco92 is offline   Reply With Quote
Old August 22nd, 2013, 12:31 PM   #5
blackbronco92
300 Inline 6
Code U would designate an AOD-E / 4R70W
Code E would designate an E4OD
Old August 22nd, 2013, 12:45 PM   #6
chevy454
So it is an aode and not a 4r70w? I thought that since its a u code that its an 4r70w.
Old August 22nd, 2013, 12:46 PM   #7
Call a ford dealer parts department, give them last 8 of your vin.
Old August 22nd, 2013, 02:09 PM   #8
blackbronco92
300 Inline 6
Code U was used for both an AOD-E and 4R70W, as I said in the above post, they are essentially the sametransmission except that the AOD-E was used for pre-modular engines, and the 4R70W was used for the Modular engines (4.6L / 5.4L)
Old August 22nd, 2013, 02:10 PM   #9
blackbronco92
300 Inline 6
If you'd like, PM me your VIN and I will look it up for you.
Old September 15th, 2013, 07:40 PM   #10
Bjones
Bjones's Avatar
14 bolt pattern is an AODE/4R70W
Bjones is offline   Reply With Quote
Page generated in 0.29948 seconds with 53 queries
