XJ: 91 XJ Sputters, knocks, and dies - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2013, 06:09 PM   #1
hondadirtracer
Skymaster
hondadirtracer's Avatar
Default 91 XJ Sputters, knocks, and dies
I have a 91 XJ with a 4.0. It will start and idle fine for a couple seconds then it will start to idle up, then it will idle way down and start to knock. It will try to correct it but it fails and dies. It will backfire out of the exhaust and the intake sometimes, but not every time. If I play with the pedal I can get it to run higher rpms and it will run smooth before sputtering and eventually it dies. It doesn't knock when running in higher rpms. I replaced the fuel pump, filter, plugs, wires, cap, and rotor. I am getting ready to go clean the throttle body and iac right now.
https://www.youtube.com/watch?v=CNqt...e_gdata_player
hondadirtracer is online now   Reply With Quote
Old August 20th, 2013, 08:44 PM   #2
xNewhaven11
Four Wheel Drive
xNewhaven11's Avatar
Send a message via AIM to xNewhaven11 Send a message via MSN to xNewhaven11
Cleaned out the IAC and the throttle body. Still making the sme noises. The sound seems like it is coming from the flywheel or something in that area.
xNewhaven11 is offline   Reply With Quote
Old August 20th, 2013, 09:21 PM   #3
DirkJanseVan
Sounds like a bad crank sensor
DirkJanseVan is offline   Reply With Quote
Old August 21st, 2013, 03:02 PM   #4
hondadirtracer
Skymaster
I replaced the iac and the crank position sensor and it is still starting, idling fine for a couple secs, then idles down and starts knocking, idles up without knocking, then idles down again. It will go up and down a few times before stalling.
Old August 21st, 2013, 05:46 PM   #5
hondadirtracer
Skymaster
I checked all of the vac lines and they look ok. I don't want to keep throwing parts at it but what about the map sensor?
Old August 21st, 2013, 06:36 PM   #6
hondadirtracer
Skymaster
Just put in a map sensor. Still doing the same thing.
Old August 22nd, 2013, 03:49 PM   #7
hondadirtracer
Skymaster
Anyone have any ideas? It's not drive able so I can't take it to get scanned. Someone I know suggested a vacuum leak but I didn't think it would cause the motor to run like this.
Old August 22nd, 2013, 07:16 PM   #8
firehawk
Live Action!
firehawk's Avatar
Did you check fuel pressure?
Old August 22nd, 2013, 10:04 PM   #9
hondadirtracer
Skymaster
Planning on renting a tester tomorrow. I will post the results.
Old August 24th, 2013, 09:27 AM   #10
hondadirtracer
Skymaster
Tested the fuel pressure last night. Has 40 psi with the key on then it bleeds down to about 35 and holds it. When it starts it has about 40, then bleeds off to 0 and starts knocking and dying then the pressure jumps to 40 again before repeating the bleed down and knock routine. It has a new fuel pump and filter.
Old August 24th, 2013, 10:31 AM   #11
firehawk
Live Action!
firehawk's Avatar
Possibly its the computer or some bad wiring.
Not sure if the fuel pressure regulator can do that but I dont think so.
Old August 24th, 2013, 10:43 AM   #12
GREASYHANDS
GREASYHANDS's Avatar
Its a bad resistor on the drivers fender. Eliminate it.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 24th, 2013, 11:34 AM   #13
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I was trying to find a thread on that. Buddy had the same problem.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old August 24th, 2013, 12:34 PM   #14
GREASYHANDS
Mine left me stuck twice. I finally bypassed it no more problems or running lean
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 24th, 2013, 01:07 PM   #15
hondadirtracer
Skymaster
A quick googling comes up with the fuel pump ballast resistor. Would that be the one?
Old August 24th, 2013, 01:31 PM   #16
GREASYHANDS
Yes its near the firewall
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 25th, 2013, 04:39 PM   #17
hondadirtracer
Skymaster
That fixed that problem. Thanks for the help.
Old September 5th, 2013, 10:33 AM   #18
Guy's wife jeep
Guy's wife jeep's Avatar
where did you find that resister
Guy's wife jeep is offline   Reply With Quote
Old September 14th, 2013, 04:00 PM   #19
hondadirtracer
Skymaster
It's on the inside of the driver side fender near the firewall. It is 1 wire in and 1 wire out. I just cut off the connectors and soldered the wires together. The resistor is there to reduce voltage going to the fuel pump to make it quieter. The only warning I found was to not let the fuel level get too low because the pump will be running a little hotter.
Page generated in 0.40692 seconds with 80 queries
