Axles+tires=gears - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 29th, 2013, 02:10 PM   #41
montecarlo33
The Violator
montecarlo33's Avatar
Originally Posted by Hoss Blazer View Post
X2
That's what I did w/ my rear.
who did you use? Or did you weld it up yourself?
Old August 29th, 2013, 02:24 PM   #42
Carbon
Yooper
Carbon's Avatar
I could do that. I wouldn't know where to begin with sizes and stuff.
Carbon is offline   Reply With Quote
Old August 29th, 2013, 02:25 PM   #43
Carbon
Yooper
Carbon's Avatar
I do have all the old shafts thought about making some.
Old August 29th, 2013, 02:37 PM   #44
You need to be able to flex your suspension from full stuff to full droop. Measure yoke to yoke in both positions and that tells you want your driveshaft lengths need to be.
At full droop you need to use a protractor to see what angle your driveshaft is at. That will tell you if you need single or double cardan joints.
Old August 29th, 2013, 05:00 PM   #45
Carbon
Yooper
Carbon's Avatar
Ok I'll do some research on building drive shafts. I'm sure there is a ton of info out there. Thanks for your help. I'd rather snap some home made shafts getting it right then blow $800+ on shafts. I could use that money for high horse power stickers and stuff.
Old August 29th, 2013, 10:31 PM   #46
cerial
Direct Drive FTW
cerial's Avatar
A Dana 20 is not bullet proof and anything can break given enough stupidity.
I have a completely rebuilt/never ran sm465/d20/18 with every option herm the overdrive guy could install in it that is collecting dust for over a year because I upgraded to an engine that will break the case in two with my "F it I can make that" attitude.
Yes, a terra low kit will be harder on your joints and pinions. That's why I recommended larger joints and beefing the pinion. I don't know why you wouldn't go double cv the cost is not much more.
4.10x2=8.20
4.10x3.15=12.91
5.38x2=10.76
Lots of guys myself included have got to the top of hills many times with nothing more then a 40/1 ratio. They had 100x raitos, big blocks, and big azz tires. I had a 4 banger, 28" tires and a welded rear.
Gear ratios and big tires don't mean jack if you can not get traction.
I don't see whats wrong with the 38's and ratio you currently have. Shave that pig and install a locker. If you feel you need more gear you can install it later.
cerial is online now   Reply With Quote
Old August 30th, 2013, 09:58 AM   #47
Carbon
Yooper
Carbon's Avatar
4.10x2=8.20
4.10x3.15=12.91
5.38x2=10.76
Thats actually a solid plan. I will get the drive line finished and play with it as is to see what I need. I don't know how much longer I can look at in my garage and not be able to drive it around the yard.
Old August 30th, 2013, 10:31 AM   #48
If you stay with 4.10 gearing and 38's and do much serious technical wheeling you will regret it. There's a reason that most (unlike cerial) go deeper gears with taller tires.
I've never bothered to calculate final drive ratio as much as knowing what works by usage and observation. Regarless of the ratio of your tranny 1st gear, it seems that transfer case and axle ratios come more into play in the real world.
Old August 30th, 2013, 03:35 PM   #49
Carbon
Yooper
Carbon's Avatar
Oh I definitely plan to go deeper with my gears. I guess it would be nice to get a bench mark where its at and improve on it from there.
Old August 30th, 2013, 03:46 PM   #50
liv2mx
i like jungle gym's.
liv2mx's Avatar
I run 4:10 gears, stock ford 205 and 46" tires. whats the gearing work out to be?
my point is depends on your setup.i have a nv4500 with a low first and awesome second.so I run 2 and 3rd low wheeling, first for crawling and hi for the dunes and going fast.i like a big ring and pinion. and wheel speed when needed..but I am the 1% president..
crawling is for babies!
Old August 30th, 2013, 03:50 PM   #51
Carbon
Yooper
Carbon's Avatar
I like your avatar. Got a bigger picture of that?
Old August 30th, 2013, 03:53 PM   #52
liv2mx
liv2mx's Avatar
that's me and I have many pictures on here if you look at my build thread or the picture thread.
Old August 30th, 2013, 04:08 PM   #53
Carbon
Yooper
Carbon's Avatar
Awesome!
Old August 30th, 2013, 05:17 PM   #54
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Old August 30th, 2013, 05:19 PM   #55
Carbon
Yooper
Carbon's Avatar
Thanks for the new wall paper on my laptop. :)
Old August 30th, 2013, 07:11 PM   #56
Please do not encourage him.
Old August 30th, 2013, 07:12 PM   #57
And you have more HP and engine RPM range than he does. Plus you drive like a pansy.
Old August 30th, 2013, 09:16 PM   #58
Carbon
Yooper
Carbon's Avatar
Hahaha
Page generated in 0.44457 seconds with 78 queries
