Axles+tires=gears - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2013, 09:32 PM   #1
Carbon
Yooper
Carbon's Avatar
Default Axles+tires=gears
I have a front Dana 44 and a rear corp 14 bolt out of a 79 3/4 gmc that I installed under my 76 Scout II with a 345 v8. Currently I have 4.10 gears. My plan is to run 40's and would like to regear to 5.13 or 5.71. My question is, will both axles accept this size gear set?
Carbon is offline   Reply With Quote
Old August 19th, 2013, 09:35 PM   #2
I believe 5.38 is as deep as the 14b gets.
Old August 19th, 2013, 09:39 PM   #3
Carbon
Yooper
Carbon's Avatar
Will that be enough? This will be off road only. Trails, climbing and maybe some mud.
Old August 27th, 2013, 05:50 PM   #4
cerial
Direct Drive FTW
cerial's Avatar
What was your previous tire size?
For instance if you had a 35"'s with 4.10 gears and step up to 5.38 that's a increase in torque of 1.312. The tire size going up to 40's will reduce your torque by .875 giving you an increase in torque of 0.43%. So the feel should be similar as with the 35" tires. Now, If you had smaller then 35" tires before then you would feel a loss in torque.
That's just round wheel numbers not figuring in traction, a different rim, tire weight, or anything else you may gain or loose by going with the larger tire size.
If you were smaller then 35" before going with a higher reduction in the transfer case will give you more torque.
Old August 27th, 2013, 05:56 PM   #5
ReiKo
Community Smart Ass.....
ReiKo's Avatar
I thought Dana 44 could only go to 4:88?
ReiKo is offline   Reply With Quote
Old August 27th, 2013, 06:09 PM   #6
curbdog17
Mini Van
curbdog17's Avatar
I Have 5.38 In My Dana44.
Old August 27th, 2013, 06:10 PM   #7
no, can go to 5.88.
5.71 gears I don't think are available for either.
Old August 27th, 2013, 09:17 PM   #8
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Originally Posted by cheapthrillb2 View Post
i believe 5.38 is as deep as the 14b gets.
x2
CHEVYRCKS is offline   Reply With Quote
Old August 27th, 2013, 11:51 PM   #9
Carbon
Yooper
Carbon's Avatar
Building the truck from the ground up more or less. I have 38" rollers on it now. Want to go 40's due to the huge 14b hanging low. I don't have the need or desire to go bigger then 40's so I'm looking for the right gear ratio for what I want.
Old August 27th, 2013, 11:52 PM   #10
Carbon
Yooper
Carbon's Avatar
So 5.38 is what I'm looking at?
Old August 27th, 2013, 11:57 PM   #11
Wramblerguy
Wramblerguy's Avatar
It's your deepest option
3rd generation jeeper
Old August 28th, 2013, 12:33 AM   #12
Shotgun
I only wheel with boats.
Shotgun's Avatar
Shave it, that would be an easier option.
Old August 28th, 2013, 06:03 AM   #13
Carbon
Yooper
Carbon's Avatar
Thought about that. Still need to do some research on how much to grind and how strong the housing will still be.
Old August 28th, 2013, 07:28 AM   #14
5.38 will be fine. 5.13 or 5.38 is what most of the guys with 6 cylinders are running with great success. I'm running 4.88 but have more motor than some. Don't forget your transfer case ratio plays into this also. What do you have?
Old August 28th, 2013, 07:57 AM   #15
redhead_823
redhead_823's Avatar
Transfer case should be Dana 20 with about 2:1 ratio. You can get the tera-low kit for about $1000.
What transmission do you have?
redhead_823 is offline   Reply With Quote
Old August 28th, 2013, 08:04 AM   #16
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Look at any of the 14 bolt shave kits on the market. Most are priced fairly reasonably, and if you know someone with access to a lathe, your ring gear is easily shaved to match...
Cheap Thrills Off Road
Old August 28th, 2013, 10:56 AM   #17
Carbon
Yooper
Carbon's Avatar
Yes the tcase is a Dana 20. I have not identified the transmission yet. I have a stock IH 345 under the hood. I will look into the shave kits. I also have access to a lathe.
Old August 28th, 2013, 11:00 AM   #18
Carbon
Yooper
Carbon's Avatar
So your saying shave it, stick with 38's and 4.10s?
Old August 28th, 2013, 11:10 AM   #19
No, shave it and go to a 5.13. 4.10 is too high of a gear for a 38 or 40" tire.
Old August 28th, 2013, 11:17 AM   #20
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
I run 38.5 monster mudders w/ 4.10's right now. I ran the last mud run in 4h, should have been in 4L. Didn't rev up past 3500 the whole time. I just picked up a set of 5.13's. So we'll see what happens!
Page generated in 0.35915 seconds with 84 queries
