. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2013, 07:06 PM   #1
jeepbrattt
New car smell.....Mmmmmmm
Default .
jeepbrattt is offline   Reply With Quote
Old August 16th, 2013, 07:15 PM   #2
buttercr125
I work out
buttercr125's Avatar
Yeah I seen your post about this on FB. I can get that sensor for quite a bit less than that. I can get an aftermarket sensor for $120 but wouldn't be able to call them till Monday on it. I would have someone double check it to make sure that is the issue.
Old August 16th, 2013, 09:00 PM   #3
hamsmotorsports
hamsmotorsports's Avatar
Just unplug the Icp connector and it will probly have oil in it. If so change or clean the pigtail good when you install the new sensor.
hamsmotorsports is offline   Reply With Quote
Old August 16th, 2013, 10:59 PM   #4
zebrazuk
First day on the job
zebrazuk's Avatar
Dieselorings.com $147 free shipping. Sells all the quality parts, cheapest on the good racor fuel filters also(ford motorcraft reboxes these). Do as stated above, clean or replace pigtail connection.
zebrazuk is offline   Reply With Quote
Old October 26th, 2013, 07:58 AM   #5
Hoofinit
Hoofinit's Avatar
Aftermatket crank sensors pick up noise from wiper motor. Will make truck stall intermittently, there is a recall on that sensor.
Hoofinit is offline   Reply With Quote
Page generated in 0.17558 seconds with 38 queries
