is it worth fixing? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2013, 09:32 AM   #1
Toyfish
Toyfish's Avatar
Default is it worth fixing?
i have a 98 xj i just picked up and it has a rod knock is it really worth trying to swap out rod bearings or shound i just save up some cash and put in a used motor? my plan is to dd this so i can park my tj.
Old August 16th, 2013, 09:44 AM   #2
jaysusr
jaysusr's Avatar
Pull it, send it out to be rebuilt, make sure to get improved casting head, re install. That's what id do, these are good motors after the head issue is resolved. Just my .o2
Old August 16th, 2013, 09:49 AM   #3
4.7 stroker or 5.3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2013, 09:59 AM   #4
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Old August 16th, 2013, 10:04 AM   #5
Toyfish
Toyfish's Avatar
lol... hey now i picked this thing up for $350 and put in a used pcm to make it run but it knocks ill part it out before rebuilding the whole motor it has 230,000 miles on it. im just looking to cheaply fix it im only considering fixing it cuz it has a clean body.
Old August 16th, 2013, 10:06 AM   #6
Old August 16th, 2013, 12:14 PM   #7
skife
skife's Avatar
is it really knocking? or are the flexplate bolts just loose?
Old August 16th, 2013, 01:45 PM   #8
hghgrad
hghgrad's Avatar
I've picked up clean motors for $2-300. If you have a clean body, its worth looking for a decent motor. Cherokees aren't worth that much parted out.
hghgrad is offline   Reply With Quote
Old August 16th, 2013, 02:21 PM   #9
skife
skife's Avatar
Tell that to 1x1speedcraig
Old August 16th, 2013, 02:35 PM   #10
Toyfish
Toyfish's Avatar
well i just dropped the oil pan and the number 6 piston is broke...
Old August 16th, 2013, 04:17 PM   #11
skife
skife's Avatar
skirt is broke?
Old August 16th, 2013, 04:24 PM   #12
Toyfish
Toyfish's Avatar
Originally Posted by skife View Post
skirt is broke?
Yup
Sent from my DROID X2 using Tapatalk 2
Old August 16th, 2013, 05:12 PM   #13
curbdog17
Mini Van
curbdog17's Avatar
I had the same problem with my engine a couple years ago. I took the Pistons from a blown motor and put them into another motor with broken pistons zero machine work was Done and the motor Is running fine for the last 2 years and does not smoke. I also put main bearings and lifters in while I have the motor taken apart.
Old August 16th, 2013, 06:06 PM   #14
Toyfish
Toyfish's Avatar
Yea this is kind of what im thinking of doing i pulled the head off today so this weekend ill pull the pistons and check everything out
Old August 16th, 2013, 07:22 PM   #15
GREASYHANDS
GREASYHANDS's Avatar
Skeetown engine werks ftw!!!!!!
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 16th, 2013, 08:26 PM   #16
af26yrs
af26yrs's Avatar
4.0 common broke pistons. Had to have mine rebuilt for it. Sounded like a rod knock but just a broke piston.
af26yrs is offline   Reply With Quote
Old August 16th, 2013, 10:20 PM   #17
joe_jeep
welfare wheeler
joe_jeep's Avatar
pistons, and gaskets are cheap.
look at the timing chain, see if it needs one.
rod and main bearings.
hone it lightly, mabey rings?
water pump, and oil pump while its apart?
all cheap and easy stuff.
Old August 17th, 2013, 09:55 AM   #18
Toyfish
Toyfish's Avatar
Yea this is pretty much everything i planed on doing to it
Old August 28th, 2013, 03:18 AM   #19
Ajhawk
Ajhawk's Avatar
honestly, if youre not gonna beat on it, and just keep it a dd, if the rod knock isnt terrible, dont bother with it, my 94 zj (4.0) had a rod knock for around a year, still had it when i sold it to a friend, and she still drives it to this day, if its not to bad, wouldnt bother with it, the 4.0's last forever, like i said, just dont ream on it.
Ajhawk is offline   Reply With Quote
Old September 22nd, 2013, 04:04 PM   #20
Toyfish
Toyfish's Avatar
Well if anyones cares to know i got a steal on a 4.0 with 125k on it so i stuffed in the new motor and shes running great!
Page generated in 0.45938 seconds with 84 queries
