Fall Crawl Capreol - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old August 14th, 2013, 04:16 PM   #1
nickel4x4
Default Fall Crawl Capreol
Please post up any available weekends in October to schedule a comp. So far it is looking like the 19 &20th.
We made a lot of improvements to the courses and gave a few more in store before fall.
As well, Im going to put $500 of my own money on that wall!!!
there will be some stipulations to it, 3attempts with no adding material to ir as an aid, than 3 attempts with the addition of rocks at the bottom... First one up takes the cash!
I attempted it a couple times and didnt get far at all.
Thanks,
Sam
nickel4x4 is offline   Reply With Quote
Old August 15th, 2013, 10:45 AM   #2
busyfixin
Balls Deep
busyfixin's Avatar
I can't say if I could make it for sure or not, but that seems like a possible weekend, and gives a little bit of time for repairs after Loonie.
Old October 6th, 2013, 03:50 PM   #3
nickel4x4
It took me a while to get everything lined up with the city to make this a go but I have done it.
Oct 19 at 11 am
Capreol Ski Hill
Stock class, Modified class and unlimited class
Truck requirements;
Stock Class:
All OEM Frame
OEM wheel base
OEM style suspension with a bolt on lift kit. If it came from the factory with leafs, it has to keep leafs. A TJ with a long arm kit is allowed the rear wishbone style upper control arm but no custom suspensions or modified lift kits.
Vehicles with removeable tops are required to have a roll bar.OEM Jeep cages are acceptable
Vehicles must be plated and insured.
Must have full doors on and a hard top.Vehicles with removable hard tops can skin the roof area with tin or alluminum minimum of 16ga thick.
OEM seat belts minimal.
No axle swaps.
No engine swaps
No under drives or doublers.
No Transfer case swaps such as an atlas, STAK or rubicon case into a TJ.
No sticky tires, No cut tires or siping
Tire sizes up to 36" only.
No hydraulic assist or full hydro steering.
Gas tank must be in stock location.
DOT Helmets must be worn by both driver and co driver.
All vehicle components containing fluid or oil must be free of leaks
A min. of one 2 1/2 lb fire extinguishers, one within reach of driver or co-driver
First Aid Kit
Stock Modified:
6" wheel base stretch maximum
Suspension changes allowed, leaf to 4 link, custom suspension, coil overs and air shocks allowed
Roll bar manditory
Axle swaps allowed
Under drives, doublers and after market transfer cases allowed.
engine swaps allowed
No sticky tires, no cut tires. Siping is allowed as long as the sipes are no more than 1/4" in width and no more than 2 per lug. I.E. a V or X shape sipes on a TSL is allowed.
Tire size up to 40" only.
Hydraulic assist and full hydro systems allowed.
Gas tank can be relocated. must be strapped into place and protected from possible driveshaft breach If it is inside the passenger compartment a fire wall is required around it. This fire wall must be made of sheet metal. The fire wall must be secured in place adequately as not to allow it to move away from the fuel tank during a rollover and must use a shut off valve accessible from either side of the vehicle.
First Aid Kit
Unlimited Class:
Any chassis modifications or custom built allowed (buggy's, truggy's or jeep buggy's)
Full cage around the entire drivers compartment including at least one door bar at least waist high, cross bar along the wind shield area top and bottom and behind the driver and passengers seats top, center and bottom (an X is acceptable behind the seat.)
Door panels are a must
Window nets are mandatory
Roof panel is mandatory.
5 point harness mandatory
Any Drive train allowed (engine, tranny, transfer case, under drives, axles)
Any style suspension.
Any size tires, sticky, cut and siped allowed.
Vehicles not equipped with a stock steering column with a functioning ignition switch must have a "deadman" switch installed that will remove all power to the engine and fuel system - it must be easily accessible to either occupant or support staff.
DOT Helmets for driver and co driver mandatory.
Fire Suits for Driver & Co-Driver, are mandatory
First Aid Kit
there will also be a bounty climb on the wall as meantioned. $500 so far but working on sponsors to pitch in and make the pot bigger.
Hope to see you guys out here. PM or post up for any additional details needed.
Sam
Old October 6th, 2013, 03:58 PM   #4
nickel4x4
Old October 11th, 2013, 04:58 PM   #5
nickel4x4
Any one coming to compete?
Old October 14th, 2013, 08:32 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
How is this shaping up and where the heck is it?
Old October 14th, 2013, 08:45 PM   #7
Google is your friend.
Capreol Capreol
http://capreolonline.com/cap/about.html
http://www.capreol.info/
http://www.capreol.info/areamap.html
Old October 14th, 2013, 09:21 PM   #8
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Listen up Buggy Tim... If it is in Canada, just ask a Canadian...
Cheap Thrills Off Road
Old October 15th, 2013, 06:05 PM   #9
nickel4x4
Its shaping up well.
We have opened a side by side class, Stock and Mod are showing over a dozen competitors so far, Unlimited has a few confirmed and another 6 or so on the fence pending more competition in that class.
the unlimited class will have a crawl consisting of 2 stages with 3 gates and a bonus on each, than a shootout between the leaders as well as optional short course race and a crack at the "Wall" for a chance to take $500 of my money
There is an entry fee of $50/ class and $50 for the short course race, and entry into either will get you a shot at the wall, no extra charge!
So come out!
Sam
Old October 15th, 2013, 06:08 PM   #10
nickel4x4
Here is a sample video of the short course race from last year.
We have made some changes to the course, the big tech section closest to the camera man is a bit bigger now.
Sam
Old October 15th, 2013, 09:14 PM   #11
busyfixin
Balls Deep
busyfixin's Avatar
Too much safety stuff for me.
Old October 17th, 2013, 07:50 PM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
No idears it was in Canada. Too far away for me this year.
Old October 17th, 2013, 07:52 PM   #13
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
x2
Tags
meballs
Page generated in 0.48391 seconds with 63 queries
