How to approximate the cost of rewiring a house? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2013, 01:31 PM   #1
vr
vr's Avatar
Default How to approximate the cost of rewiring a house?
Is there an easy way to approximate the cost of completely rewiring a house? And before one of you jackals says call a pro.... electricians are too busy. I've called 7.
vr is offline   Reply With Quote
Old August 14th, 2013, 01:32 PM   #2
Herezja
Herezja's Avatar
Does that mean you are considering doing this yourself? Are you looing for a "guess-timate" for parts?
Herezja is offline   Reply With Quote
Old August 14th, 2013, 01:35 PM   #3
vr
vr's Avatar
No, I have to hire it done but I need a ball park of what it realistically will cost so I can budget for it.
Old August 14th, 2013, 01:35 PM   #4
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
http://www.homewyse.com/services/cos...al_wiring.html
Originally Posted by FlatFender View Post
America! Fuck yeah!
gofastbobby is offline   Reply With Quote
Old August 14th, 2013, 01:37 PM   #5
vr
vr's Avatar
Originally Posted by gofastbobby View Post
Thanks!
Old August 14th, 2013, 01:43 PM   #6
Herezja
Herezja's Avatar
Don't know about labor, but the materials for all new wiring and outlets shouldn't be too bad. Outlets are cheap, wire/cabling these days is not. I would ballpark materials for at least $600-$700 realistically (might be a little high). If you are adding a new breaker box with all new breakers add more. I would expect $1000 in materials just to be safe and that is with some padding for unexpected expenses. Probably double that in labor maybe? Depends on the size of your house and the amount of work, I would suppose.
I am just speculating here and trying to over shoot a little, but I would guess the whole thing would at least be $3000-$4000, maybe a little more depending on your specific circumstance.
Old August 14th, 2013, 02:09 PM   #7
montecarlo33
The Violator
montecarlo33's Avatar
find another electrician
Old August 14th, 2013, 03:12 PM   #8
vr
vr's Avatar
Because #8 is the magic number?
Old August 14th, 2013, 05:37 PM   #9
RyeBread
Catch the wave
RyeBread's Avatar
are you pulling all new home-runs in a house that's gutted?
home-runs in a house that still has sheetrock/plaster and will require fishing?
or just redoing a load-center/panel?
I did a panel full of breakers and a bigger box myself a few years back. I think the 200 amp Square D box full of breakers ran me $225 or so back then. It took me an entire saturday afternoon, but I was fairly particular with it.
I had been quoted $1,200 for the job.
Old August 14th, 2013, 06:01 PM   #10
chuckles123
chuckles123's Avatar
Wire the house your self hire someone to hook up the panel.remember to check the local building regs to see max distance between plugs and switches. Will be a lot cheeper then hiring ele at insane prices they charge. You will need a building permit also they will inspect work make shure hack don't burn down your place
chuckles123 is offline   Reply With Quote
Old August 14th, 2013, 06:20 PM   #11
howell_jeep
Last Free Man
howell_jeep's Avatar
I was going to call my electrician friend, but then I remembered that he is very busy.
howell_jeep is offline   Reply With Quote
Old August 14th, 2013, 07:51 PM   #12
chevotass
chevotass's Avatar
$4000
Old August 16th, 2013, 11:27 AM   #13
BOGDOG
BOGDOG's Avatar
It has been a while since I have done any side jobs but back then we charged $25 per switch or outlet if the walls were open & accessable. Material prices have gone up a lot since then.
Old August 16th, 2013, 11:56 AM   #14
Mudking
Mudking's Avatar
This.
Pulling wire is not always fun, but anyone can do it.
Save your self the money. Just hire someone to do the panel. you do all the runs, and outlet hook ups etc. The last side job we did we rewired home runs/new panel/new outlets/switches etc. It was a completed house and we did a ton if fishing/attic crawling/crawl space work. there was a PITA addition with no attic or crawl space. It was in Texas, and 110 degrees outside.
BUT, we charged 6500 (including materials) for the job. and, that was CHEAP. We should have charged more. But, the guy didnt care for permits etc. just wanted his house not to burn down.
Mudking is offline   Reply With Quote
Old August 16th, 2013, 02:30 PM   #15
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
The wire and non-20amp single pole breakers are what is expensive.
I think I have purchased four 250' spools of 12-2, two 250' spools of 14-2, one 250' spool of 12-3, and one 250' spool of 10-3. Even Leviton receptacles, switches, and plates are pretty cheap (Made in USA, usually don't break). Depending on how many 3 and 4 way switches you have, expect to spend about a hundred on them. SquareD 40 knockout 200amp panel is ~$200 on sale. I have a couple "main breaker" 16 knockout 100 amp panels for other stuff (the main breaker is being used for a switch). Two pole breakers are expensive, even 20 amp 2 pole is like $13.
I crimp and solder, always use pigtails at receptacles, et cetera so it takes me a while to do anything.
Labor is going to be killer, especially if they do a good job.
wrath is offline   Reply With Quote
Old August 16th, 2013, 04:28 PM   #16
vr
vr's Avatar
Single story house. The walls are not open. The panel needs replaced too.
Old August 17th, 2013, 11:05 AM   #17
babyjeep
iowa sucks!!!
babyjeep's Avatar
What is the reason that you are wanting to rewire?
babyjeep is offline   Reply With Quote
Old August 17th, 2013, 12:34 PM   #18
vr
vr's Avatar
It's the original wiring from when the house was built.
None of the outlets are grounded.
All of the outlets are two prong.
The breaker panel is full.
The style of breaker are no longer available.
The service mast is rusting.
And my doorbell isn't working.
Ok, really that last one wasn't a reason, but I think the others are pretty valid.
Old August 17th, 2013, 01:31 PM   #19
seadooxpguy
seadooxpguy's Avatar
If I am not mistaken, you could install a GFCI outlet at the beginning of the circuit and then replace the rest of the outlets on the circuit with a grounded plug outlet. Then replace the panel and mast and call it a day. Especially if your existing wiring is in a serviceable condition.
Some of the total house rewires I have heard about involved paper wrapped wiring and or wiring with decaying insulation that was a fire hazard. Or a combo of aluminum and copper that could also pose problems. If you just want grounded plugs and have ok wiring, you have some options. But I am not an electrician and I would check it out first.
seadooxpguy is offline   Reply With Quote
Page generated in 0.52814 seconds with 79 queries
