1986 Honda 200sx any ideas? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2013, 01:54 PM   #1
Firemedic168
Firemedic168's Avatar
Default 1986 Honda 200sx any ideas?
Hello, just picked this machine up for a couple hundred bucks and guy said it has sat for three years without starting it. Any helpful ideas on getting it going? I plan on emptying gas tank and putting new gas in. Just looking for some pointers or ideas, thanks.
Plastics and stickers look good on it, just needs an overall good cleaning,
Was parked in garage for last three years by the way
Firemedic168 is offline   Reply With Quote
Old August 13th, 2013, 02:19 PM   #2
JayBmeyer
JayBmeyer's Avatar
New gas. Take the carb apart and clean it out. New spark plug. Test compression. If all is good its a Honda it should run.
JayBmeyer is offline   Reply With Quote
Old August 13th, 2013, 03:20 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
oil the cylinder walls before u pull it over. new plug, clean carb, and new gas.
Old August 14th, 2013, 01:44 PM   #4
Firemedic168
Thank you, good idea on the carb and the spark plug, should do this tomorrow and will let u know how it goes
Old August 18th, 2013, 04:45 PM   #5
Firemedic168
Bought rebuild kit for carb, put new spark plug in and new gas, fuel will not go into carb, seems where fuel inlet is on carb won't let fuel through, not sure if that is clogged cause the holes are offset, might have to buy new carb
Old August 28th, 2013, 05:08 AM   #6
Firemedic168
Finally up and running, replaced carb and is running great
Old August 28th, 2013, 06:21 AM   #7
Mr.Green
I can levitate!
Mr.Green's Avatar
Make sure it is getting air, gas and spark. Simple.
Page generated in 0.19132 seconds with 44 queries
