Why is my jeep overheating? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 12th, 2013, 08:46 PM   #21
Toivo
Feel lucky?
Toivo's Avatar
Excessive water flow volume isn't good either. Swap to a normal flow pump and reevaluate. If the coolant moves thru the rad too quickly, it cannot lose heat efficiently and thus overheats.
Old August 12th, 2013, 08:47 PM   #22
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Problem solved!!
My new stat was bad. I bought another new stat on the way home from work. I put it in and took it for a good drive and it stayed right around 190. Thank you all for your help.
Old August 12th, 2013, 08:48 PM   #23
chadcooper55
The one I took off was a standard flow that worked fine.
Page generated in 0.31734 seconds with 32 queries
