Ground bees (help) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2013, 08:06 PM   #1
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Default Ground bees (help)
Best way to kill ground bees that are under the deck.
CHEVYRCKS is offline   Reply With Quote
Old August 11th, 2013, 08:13 PM   #2
aber61
aber61's Avatar
Soda pop in a bottle trap, set it up under the deck and wait.
aber61 is offline   Reply With Quote
Old August 11th, 2013, 08:16 PM   #3
concreteguy82
Yeah Buddy!!
concreteguy82's Avatar
gas can and a flaming arrow from 20 yds
concreteguy82 is offline   Reply With Quote
Old August 11th, 2013, 08:20 PM   #4
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
Expanding foam insulation and a long vinyl tube. Stick the tube right down into the hole, attach the spray foam and pump away.
Old August 11th, 2013, 08:26 PM   #5
skife
skife's Avatar
they ground bees or cicada killers?
http://www.theatlantic.com/national/...coming/277688/
Old August 11th, 2013, 08:29 PM   #6
wakeboard76
wakeboard76's Avatar
just pour gasoline directly into the hole, best to do in early am, usually will kill them all without even being lit. we do it at my golf course whenever we find a nest.
wakeboard76 is online now   Reply With Quote
Old August 11th, 2013, 08:30 PM   #7
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Its like 5 feet from the house and under the deck... so I'm noy doing that.
Not sure how well that will work being that it is hard to get to the hole and it looks like there might be a few holes.
Old August 11th, 2013, 08:32 PM   #8
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I pour sevin dust in the entrance in the evening. Most of the time I don't need a second apply.
Sevin is available at the hardware store.
Old August 11th, 2013, 08:33 PM   #9
Jiveturkey3
Jiveturkey3's Avatar
Shop vac? Bee spray? Boom?
Jiveturkey3 is offline   Reply With Quote
Old August 11th, 2013, 08:35 PM   #10
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I might try that.
Old August 11th, 2013, 08:35 PM   #11
howell_jeep
Last Free Man
howell_jeep's Avatar
If they are bees, call a beekeeper and they will remove them. If they are wasps, then if you can get under the deck, find the hole and mark it. Come back in the evening with a window screen and boiling water. Put screen over the hole and then pull hot water into the hole.
If you can't get under the deck, you can just try to flood them. soak the area and it will eventually collapse their nest, killing the queen inside.
howell_jeep is offline   Reply With Quote
Old August 11th, 2013, 08:36 PM   #12
aber61
aber61's Avatar
Old August 11th, 2013, 08:36 PM   #13
BlooMule
Old School
BlooMule's Avatar
-rw-rw-rw
Old August 11th, 2013, 08:38 PM   #14
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Gas right down the hole in the early morning works. Don't just wait till it gets dark. They will still chase you in the dark if they're warm.
Old August 11th, 2013, 08:39 PM   #15
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I did pour this stuff I got from a friend, that is a white powder that he used for fleas on his dogs. Not sure if that is sevin dust. I know it did work for ants.
Old August 11th, 2013, 08:41 PM   #16
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I just made two
Old August 11th, 2013, 08:41 PM   #17
firehawk
Live Action!
firehawk's Avatar
Eat them!
Old August 11th, 2013, 08:45 PM   #18
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
They are bees not wasps.
I can get under there, but don't know how fast I can get out if they attack...... so I am not going under there.
Old August 11th, 2013, 08:50 PM   #19
aber61
aber61's Avatar
this one has a 4x4 in the backround
Old August 11th, 2013, 08:51 PM   #20
Bullhed78
Bullhed78's Avatar
What I did to kill the nest I had in my yard is this.
1. During the day very slowly and cautiously place a stake marking the entrance hole so you can easily find it at night.
2. Then in the middle of the night slowly walk up and cover the hole with a clear Tupperware container or clear glass bowl. Whatever you use must be clear.
3.Seal around the edge of the bowl with dirt or sand so they can't just crawl under it.
4.Let it set for a couple weeks and the colony will be dead.
If there is more than one entrance you will have to cover them all and leave it covered longer because the hive is obviously big. What happens is since the bees can see daylight they don't realize they are trapped so they won't dig their way out and eventually die of starvation.
Bullhed78 is offline   Reply With Quote
Page generated in 0.33870 seconds with 84 queries
