Broke TJ Upper Shock Bolts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2013, 10:26 AM   #1
ckhanna71
ckhanna71's Avatar
Default Broke TJ Upper Shock Bolts
Putting a lift on a 99 TJ and when removing the rear shocks I had a bolt break on each side in the tub. Best way to get them out? Cut access holes in the tub? Any ideas or comments?
ckhanna71 is offline   Reply With Quote
Old August 11th, 2013, 11:42 AM   #2
DZWrangler
DZWrangler's Avatar
I just went through this about 6 months ago. Do the broken bolts spin? If they dont then you can just put a nut on the broken bolt threads thats what I did. If they do spin then its a little more tricky.
DZWrangler is offline   Reply With Quote
Old August 11th, 2013, 11:48 AM   #3
ckhanna71
ckhanna71's Avatar
No, they broke clean off in the tub
Old August 11th, 2013, 12:02 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
TJ nuts are welded better than XJ's. My trick for the broken bolts is air hammer the broken bolt/nut out of the way and drop new bolts in nut it and finish. I did have a couple break on one with a body lift one time, so I just put some heat on the nut and spun the broken bolt out from the top with a stud puller.
Old August 11th, 2013, 12:26 PM   #5
ckhanna71
ckhanna71's Avatar
Ok, how did you get a wrench on the top of the new bolt after you knocked the old one out of the way?
Old August 11th, 2013, 12:29 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
I didn't. Air gun spun it tight in no time. If you have a welder handy, you can tack the bolt to the frame.
Old August 11th, 2013, 12:31 PM   #7
ckhanna71
ckhanna71's Avatar
Ok I see, I have both. Wasn't sure if a air hammer would push the old bolt up and out of the way.
Old August 11th, 2013, 12:33 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
The broken parts will be out of the way enough to get a new bolt in the hole. The frame is in two layers there. The new bolt will end up on the outside layer.
Old August 11th, 2013, 12:35 PM   #9
ckhanna71
ckhanna71's Avatar
I appreciate it, I will give it a shot
Old August 12th, 2013, 02:41 PM   #10
idiot magnet
idiot magnet's Avatar
It's time to out board the shocks and be done with the crappy factory mounts.
idiot magnet is offline   Reply With Quote
Old August 13th, 2013, 05:12 AM   #11
ckhanna71
ckhanna71's Avatar
I will have to investigate that, not sure I know how
Page generated in 0.26599 seconds with 56 queries
