miller 180 gas problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2013, 04:14 PM   #1
sluginxlt
tooweel or not tooweel
sluginxlt's Avatar
Default miller 180 gas problem
I have a millermatic 180 mig welder that i bought new 6 years ago. It has been a great machine until now, the sheilding gas is always flowing when the welder is on. as soon as i turn on the welder you hear the click of the gas solenoid that you usually hear when you pull the trigger. If anybody knows anything about them please help me figure it out.
sluginxlt is offline   Reply With Quote
Old August 7th, 2013, 04:20 PM   #2
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
does it stop when you diconnect small plug from whip on front of welder? i suspect bad switch or pinched wire
Old August 7th, 2013, 05:49 PM   #3
sluginxlt
sluginxlt's Avatar
no i didnt try that but that is a great idea! i read that it could be trigger, solenoid, or circut board but wasnt sure how to determine but your advice will answer if its in the gun or not.
Old August 7th, 2013, 09:26 PM   #4
sluginxlt
sluginxlt's Avatar
well i went out to the garage and unplugged the wire from the gun to the machine and the gas flow still come on when i turn on the welder. I decided to remove the cover to see whats inside. theres 2 wires running to the gas valve i unplugged the white wire "not knowing what im doing" and then turned the machine on and the gas has stopped so i guess that means the valve is not physically stuck. so now could it be the valve solenoid or is it the board?
Old August 7th, 2013, 09:36 PM   #5
jeepm715
DEAK Racing
jeepm715's Avatar
Solenoid is good, otherwise it would never stop. There has to be a relay that fires the gas valve that is stuck closed, so when you flip the power switch on it charges the solenoid. May be a cube relay, or it could be built into the board. Tap gently on all the little black boxes on the circuit board and one of then may release and stop the gas.
DEAK Racing
jeepm715 is offline   Reply With Quote
Old August 9th, 2013, 06:30 PM   #6
joe&jeep
WHISKEY-TANGO-FOXTROT
joe&jeep's Avatar
if you lived closer I could take a look at it, I beleive the problem will be circuit board
joe&jeep is offline   Reply With Quote
Old August 9th, 2013, 07:55 PM   #7
muddinman56
blood,sweat and beers
muddinman56's Avatar
Our miller 180 did the same exact thing I can't remember at the moment what it was but I remember it being something dumb and easy.
Old August 15th, 2013, 05:57 PM   #8
sluginxlt
sluginxlt's Avatar
well i hope you think hard and remember lol. i use it quite often for my projects and dont want to run out another bottle of gas on it while its broke.
Old August 21st, 2013, 07:14 PM   #9
muddinman56
If I remember correctly it was in the trigger.
It was what ever clicks the gas on was sticking open
I'm sorry I'm don't know the names of the parts but that's what it was
Page generated in 0.32858 seconds with 50 queries
