1993-1996 ford 5.0 engine ($300) and 2 wd trans($200) - $500 for set (Brighton) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2013, 10:50 AM   #1
JDBeaversllc
used auto parts resale
JDBeaversllc's Avatar
Default 1993-1996 ford 5.0 engine ($300) and 2 wd trans($200) - $500 for set (Brighton)
1993-1996 ford 5.0 engine and 2 wd trans - $200 (Brighton)
Leaflet | Map data OpenStreetMap
7580 rushton
176,xxx on truck before it was parted out
trans was in truck for 2-3 months (paid $1000 for rebuild)
$300 for engine
$200 for trans
unfortunately we did not receive receipts with the trans rebuild, it is price accordingly.
$50 core charge on each
call Brandon @ JD Beavers 2484370094
m-f 9-5
sat 9-1
or come see in person at address below
7580 rushton road
brighton mi 48116
sorry no pictures at this time
exact match for 95-96 f150 f250 van and Bronco
non exact (might have to reuse your manifold oil pan or sensors
for:
86-96 f150 f250 van bronco ltd mustang cougar thunderbird grand marquis capri lincoln mark series and many more
Interchange Notes For Engine-9350K
|A| thru |M| fit as shown in notes; |J| and |M| use crank fired ignition.
Oil pans vary by options and sizes.
Wiring options vary.
WARNING: Electrical & induction systems vary, compare and switch as necessary.
Up to flywheel.
U.S. Ford 8-302 (5.0L).
Firing order; 13726548.
Horsepower ratings vary.
Mustangs use forged or hyperutectic pistons. All others use cast pistons.
Switching between carb and FI requires fuel pump eccentric and hole in timing cover, or use electric pump.
Use distributor from original vehicle.
9258B (8-351) fits; select proper oil pan & pickup by application of car & truck (4x2 or 4x4) interchangeability.
Ident: FK361AA '94-95
|A| thru |H| fit less manifolds, timing cover and oil pan.
|M| fits; difference is timing cover, intake manifolds and dampner.
E.F.I.
Sequential firing.
200 H.P.
Change timing cover between Bronco & Pickup.
Ident: 4K360AA '94-95
Ident: 4K364AA '94-95
Ident: 4K366AA '94-95
Ident: 5K360AA '94-95
Ident: 5K364AA '94-95
Ident: 5K366AA '94-95
Ident: CX36101 '94-95
Ident: EK361AA '94-95
Non Exact Interchange Notes
9350A: |B| fits; difference is upper intake.
9350A: Mark VII oil pan changes in '87.
9350A: |C| & |D| fit by switching manifolds, timing cover and fuel pump eccentric, valve covers and oil pan.
9350A: |E|, |G| & |H| fit less manifolds and timing cover.
9350A: |K| fits; difference is oil pan, manifolds and timing cover.
9350A: |M| fits; difference is oil pan, manifolds, dampner and timing cover.
9350A: E.F.I.
9350A: 54mm throttle body.
9350A: Sequential firing.
9350A: 200 H.P.
9350B: |A| fits but has less output.
9350B: Oil pan differs between '87-90 & '91 up.
9350B: |C| & |D| fit by switching manifolds, timing cover and fuel pump eccentric, valve covers and oil pan.
9350B: |E|, |G|, & |H| fit less manifolds and timing cover.
9350B: |K| fits; difference is oil pan, manifolds and timing cover.
9350B: |M| fits; difference is oil pan, manifolds, dampner and timing cover.
9350B: E.F.I.
9350B: 60mm throttle body.
9350B: Sequential firing.
9350B: 225 H.P.
9350C: |A| & |B| fits by switching manifolds, valve covers & timing cover.
9350C: |D| fits by including distributor.
9350C: |E| fits by switching timing cover, oil pan & manifolds. Fuel pump eccentric required or add electric pump.
9350C: |G|, |H| & |K| fit by switching timing cover & manifolds. Fuel pump eccentric or add electric pump.
9350C: |M| fits; difference is timing cover, manifolds, oil pan and dampner. Fuel pump eccentric required or add electric pump.
9350C: Carbureted
9350C: 4BC
9350C: Unique distributor
9350C: 210 H.P., roller cam.
9350D: |A| & |B| fits by switching manifolds, valve covers & timing cover.
9350D: 4BC
9350D: |C| fits by including distributor.
9350D: |E| fits by switching timing cover, oil pan & manifolds. Fuel pump eccentric required or add electric pump.
9350D: |G|, |H| & |K| fit by switching timing cover & manifolds. Fuel pump eccentric required or add electric pump.
9350D: |M| fits; difference is timing cover, manifolds, oil pan and dampner. Fuel pump eccentric required or add electric pump.
9350D: Carbureted.
9350D: '83 & early '84 175 H.P.
9350D: Late '84 205 H.P.
9350D: Flat tappet cam
9350E: |A|, |B|, |G| & |H| & |K| fit less manifolds, oil pan and timing cover.
9350E: |C| & |D| fit by switching timing cover, oil pan & manifolds.
9350E: |M| fits; difference is timing cover, oil pan, dampner and manifolds.
9350E: E.F.I.
9350E: Sequential firing.
9350E: Low profile intake.
9350E: 200 H.P.
9350G: |A| fits less manifolds, oil pan and timing cover.
9350G: 240 H.P.
9350G: |B| fits less manifolds, timing cover and oil pan if before '90.
9350G: |C| & |D| fit less manifolds, timing cover and oil pan.
9350G: |E| fits less timing cover and oil pan.
9350G: |H| fits less manifolds.
9350G: |K| fits less timing cover, oil pan and manifolds.
9350G: |M| fits; difference is timing cover, oil pan, dampner and manifolds.
9350G: E.F.I.
9350G: Sequential firing.
9350H: |A| fits less manifolds, oil pan and timing cover.
9350H: GT-40 manifold.
9350H: 240 H.P.
9350H: |B| fits less manifolds, timing cover and oil pan if before '90.
9350H: |C| & |D| fit less manifolds, timing cover and oil pan.
9350H: |E| fits less timing cover and oil pan.
9350H: |G| fits less manifolds.
9350H: |K| fits less timing cover, oil pan and manifolds.
9350H: |M| fits; difference is timing cover, oil pan, dampner and manifolds.
9350H: E.F.I.
9350H: Sequential firing.
9350J: Ident: 4K337BA
9350J: Ident: 4K342BA
9350J: Exact fit only.
9350J: E.F.I.
9350J: Sequential firing.
9350J: 235 H.P.
9350M: FD $2042
9350M: E.F.I.
9350M: Sequential firing.
9350M: 200 H.P.
9350M: Change timing cover between Bronco & Pickup.
9350M: Ident: TK364AA '96
9350M: Ident: TK366AA '96
9350M: Ident: ZK360AA '96
9350M: Ident: ZK361AA '96
9350M: Ident: ZK364AA '96
9350M: Ident: ZK366AA '96
9350M: |A| thru |H| fit less manifolds, timing cover and oil pan.
9350M: |K| fits; difference is timing cover, intake manifolds and dampner.
7580 rushton (google map) (yahoo map)
JDBeaversllc is offline   Reply With Quote
Old August 7th, 2013, 11:19 AM   #2
mud man
_________________________
mud man's Avatar
What transmission is this?
mud man is offline   Reply With Quote
Old August 7th, 2013, 11:20 AM   #3
mud man
mud man's Avatar
I'm looking for a AODE 2wd for a 97 F150
Old August 7th, 2013, 12:59 PM   #4
86scottsdalek10
86scottsdalek10's Avatar
X2 I'm looking for an aod
86scottsdalek10 is offline   Reply With Quote
Old August 7th, 2013, 01:36 PM   #5
JDBeaversllc
i will look into the trans for you guys
Old August 10th, 2013, 09:18 AM   #6
JDBeaversllc
yes this is an automatic with overdrive!!!
Old August 10th, 2013, 09:25 AM   #7
86scottsdalek10
Yes but is it electronically controlled as the first guy had asked hence the aod(e) or is it full manual(mechanical)
Old August 12th, 2013, 09:08 AM   #8
JDBeaversllc
slight over read sorry guys. aode Electronically controlled ..
Old August 13th, 2013, 10:47 AM   #9
JDBeaversllc
bump
Old August 15th, 2013, 08:55 AM   #10
JDBeaversllc
bump
Old August 20th, 2013, 09:30 AM   #11
JDBeaversllc
make offers
Old August 26th, 2013, 08:49 AM   #12
JDBeaversllc
bump
Page generated in 0.48494 seconds with 59 queries
