TOOLS TOOLS TOOLS snapon Mac Cornwell - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2013, 08:07 PM   #1
Junkyard
Junkyard's Avatar
Default TOOLS TOOLS TOOLS snapon Mac Cornwell
Cornwell small tool cart $375
Snap on 1/2" deep and shallow chrome sockets $75 a set (10, 12-20 deep) (10-19 shallow)
Snapon 1/2 drive deep impact socket set $150 (10-24)
Snapon bolt grip puller set $100
Snapon compression gauge with 3 extra adaptors $75 glass missing still works as it should
Snapon cylinder leakage tester $100
Snapon t handle ratchet wrench set 10-15mm $100
Snapon standard flank drive wrench set $100
Blue point snap ring pliers set $100
Blue point combustion leak tester $30
Blue point caliper piston tool $75
Mac sensor socket set $50
Mac torx plus bit set $40
Mac metric allen socket set Large $40
Mac cam lock tool $40
Mac hose pick set $25
Mac torx socket set inverted and normal $50
Mac Dodge axle tool $50
Lisel gm push rod remover $10
cornwell 90 drill $75
Cornwell 90 pencil grinder $100
Cornwell 4wd socket set $50
Matco pitman arm puller $40
Mayhew 60" pry bar $50
Snapon pry bar $40
otc ball joint press $100
ID:	111141   Click image for larger version
ID:	111142   Click image for larger version
ID:	111143   Click image for larger version
Junkyard is offline   Reply With Quote
Old August 7th, 2013, 06:27 PM   #2
Junkyard
Junkyard's Avatar
Bump
Old August 8th, 2013, 08:40 PM   #3
fordbronco
the ocean called
fordbronco's Avatar
bump..pm sent
Old August 11th, 2013, 11:10 AM   #4
Junkyard
Junkyard's Avatar
Bump
Old August 11th, 2013, 04:07 PM   #5
Easy_E
Web Wheeler !
Easy_E's Avatar
Whats the specs on the impact ? Do you make it north at all lansing area? My impact just gave up.
Easy_E is offline   Reply With Quote
Old August 11th, 2013, 04:42 PM   #6
Junkyard
Junkyard's Avatar
its 1000 something its a beast more power than the ir. I get out to lansing every week almost
Old August 11th, 2013, 08:05 PM   #7
Easy_E
Web Wheeler !
Easy_E's Avatar
Next time your this way let me know I will buy the impact . I work downtown Stjohns.
Old August 12th, 2013, 02:08 PM   #8
Blksnshn69
Blksnshn69's Avatar
I have that same impact. Great gun, well worth the $$$$.
IIRC it's 1200 ft lbs
Blksnshn69 is offline   Reply With Quote
Old August 12th, 2013, 02:55 PM   #9
Easy_E
Web Wheeler !
Easy_E's Avatar
Do you still have the ball joint press ?
Old August 13th, 2013, 05:31 PM   #10
Junkyard
Junkyard's Avatar
impact pending, snapon tool cart, large cornwell cart pending
Old August 15th, 2013, 05:45 PM   #11
Junkyard
Junkyard's Avatar
Impact sold snap on cart sold
Old August 25th, 2013, 01:11 AM   #12
Junkyard
Junkyard's Avatar
bump
Old August 25th, 2013, 08:54 AM   #13
84cj7
84cj7's Avatar
I around Monday for the torx?
84cj7 is offline   Reply With Quote
Old August 25th, 2013, 10:01 AM   #14
cannaert
No more Jeep
cannaert's Avatar
Modle number on the Snap on box that is left please.
Old August 25th, 2013, 11:38 AM   #15
Junkyard
Junkyard's Avatar
snapon cart is sold. i just have the 2 orange ones left
Old October 8th, 2013, 09:48 PM   #16
Junkyard
Junkyard's Avatar
BUMP new stuff added
Old October 10th, 2013, 12:25 PM   #17
Junkyard
Junkyard's Avatar
Bump
Old October 11th, 2013, 02:32 PM   #18
Junkyard
Junkyard's Avatar
Bump
Old October 18th, 2013, 08:01 PM   #19
Junkyard
Junkyard's Avatar
BUmp
Old October 26th, 2013, 12:12 PM   #20
Junkyard
Junkyard's Avatar
Bump possible trades for shop press want a 25 ton
Page generated in 0.29616 seconds with 84 queries
