87 chevy 1500 305 issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2013, 04:08 PM   #1
85gmc2500
85gmc2500's Avatar
Default 87 chevy 1500 305 issues
The truck starts and drives. when first starting it drops rpms a couple times and then smooths out. will drive OK when cold but as it warms up it looses power. When accelerating from a stop it will hesitate and then start going. It also backfires. Mostly from the pass. Side bank from what I can tell. Less and less often since replacing the parts I have it stalls when I put it in gear. so far I have replaced the plugs, wires, cap, rotor, fuel filter, pcv valve, coolant temp sensor on the top, map sensor, and rebuilt the throttle body. There are no vacume leaks as far as I can tell. It has gotten better with the new parts but it still has the issues. I have also adjusted the timing a little. Any ideas?
85gmc2500 is offline   Reply With Quote
Old August 6th, 2013, 04:17 PM   #2
kevinr839
kevinr839's Avatar
I have seen the distributor pick up ring get loose on the shaft and make the timing move around alot. Maybe throw a distributor in it and see what happens. I also had one that wouldn't idle good and act weird and it had really weak valve springs.
kevinr839 is offline   Reply With Quote
Old August 6th, 2013, 04:21 PM   #3
85gmc2500
85gmc2500's Avatar
It only drops rpms a couple times and then idles OK. I left it for 10-15 minutes idling this morning and it was fine. The distributor looked rusty as hell so that may be possible.
Page generated in 0.88356 seconds with 32 queries
